Old 04-19-2003, 09:39 AM   #1
YeuEmMaiMai
Default sign of a bad radiator cap?
Just a quick question
my 94 accord LX with 104K started to blow coolant out of the overflow tank . At first I thought it was a blown head gasket so I did the following
1. I took the cap off of the radiator started the car up and let it run but no air is bubbling out of the radiator
2. when the car cools down it DOES NOT draw coolant into the system like it should as you can see the hoses collapse (that I have never seen before)
3. No coolant in the oil
4 car idles just fine and no crap on any of the plugs.
does this sound like a bad cap as it is not holding pressure and it is not drawing coolant into the system.
YeuEmMaiMai is offline   Reply With Quote
Old 04-19-2003, 10:43 AM   #2
Chiovnidca
Chiovnidca's Avatar
Default Re: sign of a bad radiator cap? (YeuEmMaiMai)
Yes, it's bad. The one way valve is stuck on it.
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
Old 04-20-2003, 07:33 AM   #3
YeuEmMaiMai
Default Re: sign of a bad radiator cap? (TurboD16Chiovnidca)
would that cause the other problem of coolant going out of the system?
Old 04-20-2003, 10:33 AM   #4
Chiovnidca
Chiovnidca's Avatar
It's not letting it back in. Click the image to open in full size.
Old 04-20-2003, 11:09 AM   #5
YeuEmMaiMai
I replaced the cap so we will see how it goes....
Old 04-20-2003, 04:44 PM   #6
YeuEmMaiMai
so far all is well.
Old 04-20-2003, 04:51 PM   #7
Chiovnidca
Chiovnidca's Avatar
so far all is well.
Old 08-18-2008, 07:29 PM   #8
bow tie
bow tie's Avatar
my 94 accord LX with 104K started to blow coolant out of the overflow tank.
bump, sorry old thread but same problem.
i'm quoting you because i've seem to develope the same problem in my 96 EX. my reservoir tank blows out coolant when i've ran the car for awhile. so i need some guidance.
like you, i also removed the radiator cap but my car showed big air bubbles (volcano) coming out. i figured there must be mad air bubbles in the system somehow. so i let it run until the bubbles started to fade. filled it up and it ran fine for about 40 mins on the hwy. but when i get to the city (stop and go) the temp rises again.
1. no coolant in oil.
2. idles fine, fans turn on.
3. coolant looks to be circulation but not sure about how fast or slow.
4. no leaks near water pump.
5. coolant fills up then bubbles out of reservoir tank.
suggestions?
bow tie is offline   Reply With Quote
Old 08-19-2008, 04:08 AM   #9
YeuEmMaiMai
Default Re: sign of a bad radiator cap? (bow tie)
replace the rad cap and do the following
1. fill the car up with coolant when engine is cold
2. start car
3. add coolant as needed
4 open bleeder valve and let any remaining bubbles out
5. top off tank and put new rad cap on
6. add coolant to the overflow tank until it is at the full mark
6. rinse engine off
over the next few days check and add coolant as needed to over flow tank
and that 94 has 180+ K on it now lol sa my friend has it
Old 09-25-2008, 07:39 PM   #10
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Sorry old thread but im having issues with my 97 GSR. My radiator hoses seem like they are barely holding any pressure in them and today when i got home i turned off my car and i hear coolant flowing when the car is off..no leaks or nothing. headgasket seems fine and im not overheating or anything. could it be a bad cap? last weekend when i first noticed my hoses not holding pressure as usual. i opened my rad cap and turned on my and let it warm back up to see if any air bubbles would come out....nothing came out after about 20 minutes so i put the cap back on..and now this so any help would be great..again its an old thread but yeah
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 09-29-2008, 03:43 AM   #11
ricebike
ricebike's Avatar
you know that autozone rents out a tool to test your radiator cap?
if you're too cheap to just replace one outright, go that route
Wife's'95 Accord LX 4dr F22b2 she gave this away to a friend since it's still mechanically sound; now has a 2005 MDX... worse mpg & takes premium to boot (she's ignoring the last part & using regular octane)
ricebike is offline   Reply With Quote
Old 09-29-2008, 09:40 AM   #12
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Default Re: (ricebike)
i aint cheap...its called asking for help or opinions from what people have experienced with.....what a dumbass...ahahah....read the topic.... Click the image to open in full size.
www.Xenocron.com
Old 09-29-2008, 04:15 PM   #13
YeuEmMaiMai
wow who knew one could bring up a thread that was nearly 5.5 years old......lol
Old 09-30-2008, 04:57 PM   #14
ricebike
ricebike's Avatar
Default Re: (mouab18c1)
i read YOUR topic;
i said goto AUTOZONE and rent that tool to pressure test your rad cap FOR FREE
then u can tell if it's bad... or do a quick visual on the rubber gasket around your cap...
what a dumbass... Click the image to open in full size.
Old 09-30-2008, 05:08 PM   #15
twkdCD595
twkdCD595's Avatar
a pressure test will tell you if it holds pressure but it will not tell you if the one way valve is working.
God bless the men and women of the U.S. armed forces.
- T1 Race Development - Injector Dynamics - Laskey Racing - PortFlow Design -
twkdCD595 is offline   Reply With Quote
Old 09-30-2008, 07:21 PM   #16
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
i read YOUR topic;
if im a dumbass then you muss be STUPID ahaha resolution solved without renting that shyt..ahahaa...feels good when asking a question is PRICELESS ahahahaha Click the image to open in full size.
www.Xenocron.com
Old 10-01-2008, 04:42 AM   #17
gqstatus05
gqstatus05's Avatar
Bedtime Ownage
Send a message via AIM to gqstatus05
That's crazy. You would think a cap should last forever. Even caps go bad.
Cars: 96 Accord LX/1990 Nissan 300ZX/98 Accord EX VTEC
gqstatus05 is offline   Reply With Quote
Old 10-01-2008, 07:05 AM   #18
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Default Re: (gqstatus05)
ahahaha...thats funny but yeah like everything else, it will go bad once in awhile....sporting a Spoon cap until further notice Click the image to open in full size.
www.Xenocron.com
abad, accord, acura, air, bad, badradiator, bubbles, cap, honda, integra, overflow, radiator, release, sign, test
