Help Needed
Old 08-30-2006, 05:16 PM
KillerBee's Avatar
Default Help Needed
I recently traded my 99 civic Si for a 97 civic with a H22A and the transmission code is weird. I did a search on this code "P2U5" and i came up with this post but no answers so i was wondering if anyone knew:
https://honda-tech.com/zerothread?id=477645
The Gears are long..
1st 0-40mph
2nd 40-70mph
3rd 70-110mph
4th well by then i slowed down
Another question, I'm trying to figure out which H22A i have. I noticed the the stamp on the head said p-13 which made me think its a 4th gen. Can anyone help with this? Also what is the redline? I currently have a burned chip and it is unlimited...however i am shifting at 7800rpm.
TIA
Old 08-30-2006, 05:35 PM
MadCityLude
Guest
Posts: n/a
Default Re: Help Needed (KillerBee)
I would get an H22 tranny and shift at 7300 unless your at the track and trying to really prove something. I wouldn't be taking it all the way to 78 everyday thats for sure. Thats alot of stress for those 50mm mains.
Old 08-30-2006, 05:43 PM
KillerBee's Avatar
Default Re: Help Needed (MadCityLude)
Actually i don't race as much as i used to but i just want to learn the H22A as much as my B16 when i had my Si. I have yet to take this car to the track and don't really intend to till i have everything the way i want and have knowledge on this subject.
I actually intend to probably get a prelude tranny in the future but am curious to what tranny i have now. Thanks MadCityLude
Old 08-30-2006, 06:02 PM
MadCityLude
Guest
Posts: n/a
I did some searching and can't find anything, I am gonna guess that it is a JDM or European Accord tranny though. With the long gears your speaking of and the fact that it hasn't been talked about in the Prelude forum here at all.
Old 08-30-2006, 06:42 PM
M2B4's Avatar
if its stamped with p13 im 90% sure its a jdm 4th gen h22. mine has p13 stamped on it and thats what mine is
Old 08-30-2006, 07:05 PM
KillerBee's Avatar
Default Re: Help Needed (M2B4)
Thats what i concluded as well, just wanted to check with others as well...what is the redline?
Also after doing some research i have found out that the P2U5 is an accord tranny (as i suspected) it is also known as the "f22a6". Here are the gear ratios:
F22a6 (p2u5)
1-3.307
2-1.809
3-1.185
4-.933
5-.685
FD-4.062
And here is where i got my answer:
http://www.cb7tuner.com/vbb/sh...20917
Old 08-30-2006, 07:13 PM
2lude4u's Avatar
The upside is you have a higher topspeed than those of us with H22 5 spds, not to mention better gas mileage. The downside is how often you do you need to go over 130mph & your acceleration isn't as good as it could be.
Old 08-30-2006, 07:31 PM
KillerBee's Avatar
Default Re: Help Needed (2lude4u)
Thats the bad, my acceleration is not what i want it to be I do get good mileage due to the longer gearing but i rather sacrifice that for better acceleration.
I am not planning on going turbo or nitrous as this would be a beautiful candidate for such application. I am not one to accelerate to top speed and would rather have a better low to midrange setup. Oh well.
Thanks everyone.
Old 08-30-2006, 07:33 PM
InvaderTrax's Avatar
Actually, gas milage is more closely related to throttle position over engine RPM. However, lower RPM's = less engine wear. Anyway, what does your engine stamp say. H22A (JDM)? H22A1 (USDM 4th gen)? H22A4 (USDM 5th gen)?
MadCityLude
Guest
Posts: n/a
no problem, we should get this tranny info added to the FAQ's.
Old 08-30-2006, 07:37 PM
M2B4's Avatar
redline from what i take it to be is 7400
KillerBee's Avatar
Default Re: (InvaderTrax)
It has a "H22A" stamp on there. But if it were a jdm, would it not have the type-s head v.s. the p13 i have now?
I mean it does have a red valve cover but it could be aftermarket so thats why i am intrigued in finding out.
Old 08-30-2006, 07:49 PM
2lude4u's Avatar
Default Re: (KillerBee)
It being JDM doesn't make it a type 'S' head, the standard JDM engine has the same head as the USDM engines, just a slightly "hotter" cam. Type 'S' heads are stamped P5P.
Old 08-30-2006, 07:53 PM
KillerBee's Avatar
Default Re: (2lude4u)
/\ I see, thanks for clearing that up. Any good place i can get info, specs, ect... for the 4th gen motor. This is where i was referring to:
https://honda-tech.com/zerothread?id=641555
Old 08-30-2006, 08:11 PM
2lude4u's Avatar
The Faq's have all of the answers to your questions, use them well:
https://honda-tech.com/zerothread/689805
i8umup
07-24-2008 01:36 PM
ekslammed
05-22-2007 12:13 PM
CapnKrunch
01-04-2007 09:54 PM
JDMH22AEG6
07-24-2005 04:18 PM
Quick Reply: Help Needed
