#1 | |||||
1995 Frost White VX. b18b power. we don't need no stinkin vtaK friends don't let friends drive with trunks http://images.honda-tech.com/set1/smile/emwink.gif |
#2 |
the VSS is sitting about 5-6 inches to the left of the starter (closest to the firewall). Its held by 2 10mm bolts.
http://www.laskeyracing.com/ Purchased parts from: ~RTErnie~, CCfab, FlatBlackDA, Kinetic motorsport, CRX12, A D NOH, Hybrid-Performance, reebs, EK-TSOHCV-TaKRider, shorbie621, xyzalvarez, ramrod, Bserieskllr, PhA53, Naudlee Sold to: Urname7698, EFb18b, Dyno247, Crx-510 '93 white gold pearl EH3 D16Z6 built/turbo http://www.honda-tech.com/zerothread?id=527859 '03 Honda CBR600RR '05 Nissan Titan LE |
#3 |
i removed both of the 10mm bolts and another close by. then i saw the pin. i pulled it out. the hole is nothing like the pic in the axle tutorial. any thoughts?
#4 |
you only need to remove the bolt that holds it into the tranny.
One bolt. Then pull it out..
89' 240sx |
#5 |
btw, this is a D-series if it matters at all
#6 |
Why are you filling it through the VSS???? There is a fill hole on the back....
I have no signature. |
#7 | |
Moderator
Most DOHC (like OBD1 B16A and all Integra B-Series trannies) and SOHC VSS are identical. All you need to do is pull the ONE 10mm as mentioned earlier and then pull the enitre VSS out - gear and all. Sounds like yours came apart upon trying to remove it. No big deal, just put it back in and take the whole thing out via the one 10mm bolt. You'll know you got it because that one 10mm bolt is really weird shaped - don't lose it!
My B18C5 1992 CX - UPDATED 8.8.08!!! My B18B-Powered 1990 Civic Wagon - FRESH y0! |
#8 |
thanks tom. i just yanked out the whole thing and voila, instant fill hole. my car is soooo much better now without that stupid clicking.
#9 |
Help we my pennies
vss?
#10 |
vehicle speed sensor damn^^^^ beat me to it
#11 | |
hx coupe 2652lbs - lsvtec--318whp/241wtq 12.54@115.57 on bfg's 92 hatch---415whp/300wtq in '07 425whp/286wtq in '08 2410lbs 12.1@125.5 1bar boost @etown fall nats |
#12 |
Once the bolt is removed, gently pry(straight up) with a flat-head screwdriver. Sometimes the corrosion holds it in tight. Also, when filling tranny through VSS, be sure to have the ACTUAL fill whole opened on the side of the tranny, so you'll know when optimal fluid level is achieved, in other words do not over fill.
| Bookmarks |
