DIY Door Panels w/ details and pics
Old 04-12-2003, 10:52 PM
151 Proof's Avatar
Default DIY Door Panels w/ details and pics
So I was bored today and decided to take care of a little interior work I been meaning to do. It's really simple and cheap, much better than buying it from a dealer or something. Basically all you need is a sq. yard of your choice of fabric. I chose black vinyl to match the rest of my car but you can go with whatever color you want like red or something if you want "CTR" style doors. THe fabric I got was only $3 per sq. yard so it's very cheap.
You'll also need some spray glue like 3M Super 90 or something similar. Spray glue is just the easiest to use. Super 77 was $10 for the only size can they had, if you can find a smaller one do it because you don't need that much.
Also get some 1/2" sheet metal screws and washers. You'll need 32 of each because there are 16 per door. Shouldn't cost you more than $5.
I just yanked the door panel off, it shouldn't be too hard, just pull and slide it out. Just remember to unscrew the door lock and the panel where the power window button is, if you have them. There's only one screw in each. There's 2 harnesses behind the passenger door and 3 harnesses behind the drivers side if you have power windows, mirrors and locks.
Passenger side with the 2 harnesses
If you have tweeters that's what the 2nd harness is for
Drivers side with the 3 harnesses
Again if you have tweeters and power locks that's what the 2 harnesses here are for
Door panels off:
There are 2 different set's of screws to take off when you remove the side pocket. One on the outside, and then one on the inside.
Now comes the fun part and the most time consuming part of the process. You have to take off all of these little plastic rivets and they are a bitch to get off. I had to use an exacto knife and a flat head screwdriver to get these SOB's off. If you have something easier to use then it should go faster. It's just that some of them are glued down and some aren't.
And when I was done each hole looked like this:
As you can see that's why you'll needs the washers, to hold it back down in place.
When all the rivets are hacked off you should be able to take out the fabic piece easy.
Now all you have to do is peel off the old fabic piece.
You can clean that green crap off if you want, but I didn't and it's fine. Depending on what type of backing that the fabic has you might want to clean it. It's a lot easier if you get a fabic that has a flat mounting surface.
Don't throw out the old fabic, you'll need it to measure the holes for the new piece. Just sketch it out and cut the holes accordingly.
Now just spray the Super 77 on the plastic as well as the back of the fabric and stick it on and smooth it out. Let it dry for about 15min before you screw it back on the panel.
Just use the washers and the screws to mount it back on and put everything back together.
Then just push the entire panel back on the door and marvel at your new door.
Finished product
I just put some door finish on the vinyl so it would match up with what was on there already so it looked nice.
It only took me about 2-3hrs to do this because of those damed plastic rivets or else it would have been done a lot quicker. Looks much nicer now if you ask me.
Oh yeah, and don't ask me what that red stuff is on the back of the panel because I have no freakin clue. No it's not blood.
Modified by 151 Proof at 12:06 AM 4/14/2003
151 Proof is offline
Old 04-12-2003, 10:55 PM
TheJediMex's Avatar
Default Re: DIY Door Panels w/ details and pics (151 Proof)
that was a nice walk-thru.
ill be saving this for when i put some red in my integra door panels
TheJediMex is offline
Old 04-12-2003, 10:57 PM
sshaikh01's Avatar
wow nice
sshaikh01 is offline
Old 04-12-2003, 11:27 PM
Nine's Avatar
Nice write up, glad it came out well for you.
Nine is offline
Old 04-12-2003, 11:43 PM
Mr. Thunderlips's Avatar
Wait until it gets hot outside and the glue lets go...I know because it happened to me. You need a stronger glue to hold the fabric...
Mr. Thunderlips is offline
Old 04-12-2003, 11:47 PM
vtechicano's Avatar
Default Re: DIY Door Panels w/ details and pics (Nine)
looks good bro. does HT have a how-to section, they should make one and put all this how-to stuff so ppl can find it quicker and newb's wont have to ask questions. l
vtechicano is offline
151 Proof's Avatar
Default Re: DIY Door Panels w/ details and pics (ThunderLips)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThunderLips &raquo;</TD></TR><TR><TD CLASS="quote">Wait until it gets hot outside and the glue lets go...I know because it happened to me. You need a stronger glue to hold the fabric...</TD></TR></TABLE>
That's why I used the glue for metal instead of the one for fabric. It has a stronger bond. Plus, it's super easy to change it now that it is screwed down instead of that dumb plastic rivets.
Old 04-13-2003, 04:08 AM
sparq's Avatar
All the pics come up as red X's now
sparq is offline
Old 04-13-2003, 04:53 AM
coupedup's Avatar
Default Re: DIY Door Panels w/ details and pics (sparq)
He reached his bandwith limit I wanted to see them too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparq &raquo;</TD></TR><TR><TD CLASS="quote">All the pics come up as red X's now </TD></TR></TABLE>
coupedup is offline
Old 04-13-2003, 05:46 AM
sleeperb's Avatar
red x's
sleeperb is offline
Old 04-13-2003, 07:10 AM
AcuraEL's Avatar
Default Re: DIY Door Panels w/ details and pics (sleeperb)
can you repost the pics again please?
AcuraEL is offline
Old 04-13-2003, 09:16 AM
151 Proof's Avatar
Default Re: DIY Door Panels w/ details and pics (AcuraEL)
Crap, they show for me. Stupid Bellsouth. I'll have to see if I can find a new server to put them on.
Old 04-13-2003, 10:05 AM
Turbo Powa's Avatar
Bandwith Limit Exceeded.
Turbo Powa is offline
Old 04-13-2003, 11:21 AM
B_CRUZ!'s Avatar
put them on imagestation or we-todds
B_CRUZ! is offline
Old 04-13-2003, 12:09 PM
95hbMatt's Avatar
Default Re: DIY Door Panels w/ details and pics (BCRUZ)
Bump! Get those pics fixed! I wanna see!!
95hbMatt is offline
Old 04-13-2003, 12:10 PM
Sushi Buffet Champion
GapxGuy's Avatar
Default Re: DIY Door Panels w/ details and pics (95hbMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hbMatt &raquo;</TD></TR><TR><TD CLASS="quote">Bump! Get those pics fixed! I wanna see!!</TD></TR></TABLE>
Me too.
GapxGuy is offline
underrated99si's Avatar
cant see a motherfuckin thing. Pleas fix
underrated99si is offline
Old 04-13-2003, 01:30 PM
Quetzolcotl's Avatar
Default Re: DIY Door Panels w/ details and pics (underrated99si)
what happened to the pics?
Quetzolcotl is offline
Old 04-13-2003, 01:37 PM
SpoonFedHatch's Avatar
Default Re: DIY Door Panels w/ details and pics (GapxGuy)
looks good dude.....i dont have one of those pockets though, the big slit one on the panel itself (92 vx, i wonder why??) anywho, i'll be doing this soon as well.....looks good bro
SpoonFedHatch is offline
Old 04-13-2003, 01:46 PM
poison's Avatar
don't see any pics
poison is offline
Old 04-13-2003, 05:03 PM
kr
kr's Avatar
Default Re: (poison)
all i see is x's blinded by the red X'
kr is offline
Old 04-13-2003, 05:49 PM
official honda whore
EARLdaSQUIRREL's Avatar
no pics, get em fixedddd
EARLdaSQUIRREL is offline
Old 04-13-2003, 08:07 PM
151 Proof's Avatar
Default Re: (coptzer)
FIXED!! I hate Bellsouth. All pics should be visible now. Sorry.
Old 04-13-2003, 08:10 PM
krazyDOHC's Avatar
Default Re: (151 Proof)
i did the same but with red cloth...looks nice..gj!
krazyDOHC is offline
Old 04-13-2003, 08:20 PM
looks nice, doesnt seem too hard, only thing id do different is try to get it so no bubbles, but i guess im just a perfectionist
Quick Reply: DIY Door Panels w/ details and pics
