make shift dust free paint room
Old 04-12-2003, 12:27 AM
216.226.142.95:27016's Avatar
Default make shift dust free paint room
when body shops paint cars, or car parts, they are suppose to paint it in a "dust free" environment. i do not have one of those rooms and in the near future i will be buying a front bumper that more than likely i have to repaint to my car's color. i do not have a dust free environment to paint it in but i do have a garage to use.
i got to thinking that maybe if i soak the garage with water it will make the dust stick to the floor, or the walls if i got that wet also. do you guys this will work? ive seen this method used in mines to keep the dust levels less than usual.
i do not have a lot of money since i go to college and my schedule does not permit me to acquire a job so i do not have a lot of money to get others to do work on my car.
Old 04-12-2003, 12:37 AM
Phoenix_ITR's Avatar
Default Re: make shift dust free paint room (216.226.142.95:27016)
you could maybe try suspending plastic sheets from the ceiling? form a little bubble around your car or something?
-tony
Old 04-12-2003, 07:35 AM
1hotintegra's Avatar
Default Re: make shift dust free paint room (delinquent)
get a fan too to push all the air out of the garage
Old 04-12-2003, 07:37 AM
xstalkrx's Avatar
be careful...that is illegal. Dont let anybody know, try to conceal it from neighbors and passing cars.
Old 04-12-2003, 09:57 AM
Default Re: make shift dust free paint room (xstalkrx)
what is illegal, painting body panels in the garage?
Old 04-12-2003, 11:14 AM
The-LS's Avatar
I think its okay to do bumper or minor things for yourself, if you are painting as a business I think its illegal because you probably need to follow environmental guidelines with chemicals and clean up + the permits stuff.
Old 04-12-2003, 11:50 AM
P1mpSlap's Avatar
Default Re: make shift dust free paint room (Black-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">I think its okay to do bumper or minor things for yourself, if you are painting as a business I think its illegal because you probably need to follow environmental guidelines with chemicals and clean up + the permits stuff.</TD></TR></TABLE>
Yup. You could get busted with an EPA violation and stuck with a fine up to 250,000 dollars or a year in jail. You gotta do something with the fumes and stuff like that properly.
Old 04-12-2003, 01:30 PM
no business here, jus trying to save myself some money. imagine the looks on my parents face when they open the garage being overcomed by fumes
Old 04-12-2003, 01:47 PM
zigs's Avatar
If all your doing is a bumper just clean the garage good put some plastic up and on the floor and itll be fine also you can wetsand any dust out of the base coat with 2000 grit be careful though base is thin not very high build and then you can also sand the clear when your done to get all the dust out then just buff it out you need a good buffer though and the right pads a rubbing compound. Ive did 2 complete color changes in my garage now and lots of little things and they look good just clean it best you can and then sand the dust out. Good luck.
Old 04-12-2003, 01:57 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 &raquo;</TD></TR><TR><TD CLASS="quote">no business here, jus trying to save myself some money. imagine the looks on my parents face when they open the garage being overcomed by fumes </TD></TR></TABLE>
That's cool. Just be sure you have a fan to evacuate the fumes and wear a respirator for protection. Good lungs are important!
christianc5692
Paint and Body
10
08-30-2010 06:50 AM
BadEH2
11-18-2004 04:07 PM
WAFFLES
71
03-18-2003 07:37 AM
tylerdurden
01-09-2003 08:20 AM
Quick Reply: make shift dust free paint room
