#1 | |||||
Pelican 1624 containing: 2 Gripped Canon 50D's, XT, XTi & XSi ♥ 10-22mm ♥ (2) - 18-55mm ♥ (2) - 50mm f/1.8 ♥ 24-105mm f/4L IS ♥ 70-200mm f/2.8L IS |
#2 |
OMG...i thought my friends and i were the only people that called it the "bitch pin."
only advice i can give ya is try and find a punch that is the right size. my dad happen to have one that was perfect. PauL |
#3 |
got mine out with a punch and a 15 lbs sledge hammer.
#4 |
Helms (or I read it somewhere) says an 8mm punch. I'm going to pick one up in the morning. Does this fit perfectly with the pin which will NOT mushroom the end?
I've got the 4lb hammer ready to go
#5 |
if you have the right size punch (honda actually has a special little tool) the pin pops out easy as pie
#6 | |
I've already took it out when I removed the Cx motor. Need to put it in the GSR
#7 |
There isn't really any tricks, maybe some WD-40, which is what I used. Once you get it started however, you can back off and just wale on it.
89' 240sx |
#8 | |
I'm going to soak it from the top side and let it drip down good and get it all lubed then just pound that bitch in there with the sledge and an 8mm punch
#9 |
i used a threaded skrew, and just hammered it in and out.
took like 3 swings with a hammer.
03' Evolving into a money pit Join my Survey Plan. Take Surveys for 6 Dollars each. |
#10 |
damn i hate the bitch pin. it was the hardest part of my swap i could not get that shit out. but getting it in was pretty easy for me, i just held it by to of my fingers and carefully hit it with a hammer to were it would stay in the hole without me using my fingers then i got a piece of 2x4 and laid it flat on the pin and just beat it 2-3 times with a hammer went in like a charm.
Hella 3rd gear vtec yo you alllll ready know!!! check out best websites in tha world ma ****ers meatspin.com lemonparty.org hai2u.com |
#11 |
1994 Acura Integra |
When you do it enuff times... it even becomes easy with a phillips head...lol
An 8mm punch is what to use to make it simple... and you should be able to do it w/ a regular hammer, as long as the car is high enuff to get a decent back swing. Step #1) Coat it lightly w/ some oil Just get it wedged in and tap it with the broadside of the hammer. You should only need the punch once it's 1/2 way in or more. A trick ? Once wedged in, you can tap the edges of the pin to help it along, but you gotta be accurate. X2 (Bitch Pin Masta)
Now :The XClone - Fastest LHD Honda in Trindad & Tobago. Then: 97 DB8- Built LSVT@12Psi - The MAGIC SHOW * R.I.P. 09-16-02* Why: "Luck can hit you like a Volvo....", X2 Always: I'd rather be turbo... 1993 DX Hatch - GSR powered, some parts are STILL stock http://images.honda-tech.com/set1/smile/emsmilep.gif |
#12 |
hammer and a center punch works well for me.
Redstone Motors - Sales & Auto Repair/Performance 727 W. Evelyn Ave Mountain View, CA 94901 (650) 967-2808 |
#13 |
In The Garage
2001 Acura IntegraJoin Date: Nov 2002
ha ha, i cussed that damn thing until i threw it into the neighbor's yard. i ended up using a bolt and locknut w/loctite (red) that was the perfect diameter. i also pulled the engine with the linkage attached. it was a whore. i had to jack the front of the car up like 2 ft, then pull out the engine. i felt like such a dumbass. now all engines go in from underneath. 2 strong people can lift up the front of a honda without an engine in it. go get some
and good luck
dAng! '01 DC231 #310 |
#14 |
i stuck a fireplace poker(you know, the one with the pointy end and little curvinglip) down the top of my engine and hit it with a sledgehammer and it bent the **** out of the poker but still came out. Victory
#15 |
Get underneath the car and use a phillips head to poke at the pin and use hammer to beat the shit out of the screwdriver. This was the most difficult part of my swap.
EK 12:1 CTR STOLEN 1/7/08. I PROMISE YOU ONE IN YOUR HEAD IF I FIND YOU K6 GSXR 600 |
#16 |
Here's how it sits as of now. I lubed it up with WD40 and hit it a few times with a sledge hammer and it did NOTHING!
I'll try again Saturday when I plan to finish the swap and fire the motor up.
#17 | |
<FONT COLOR="blue">Brendan</FONT> 1.7L DOHC - SOLD 4.0L SOHC - SOLD 1.7L SOHC - Current EMT-B |
#18 |
FYI
I've done 3 swaps already and i never took the shifter linkage out. Take one of the linkages out, the easier one nad it will give you more slack. Also if you are doing a swap you can always put the motor under the car and put it up or when dropping it in you can still clear the engine bay with the shifter linkage as long as one of them is disconnected. |
#19 |
big strong guy
1/4" Punch Works Great!
Also Any 1/4" Bolt can work too If you want to go cheap! Make sure you hold hand on back side, Being the PIN can Fly out on the last hit and you WIll NEVER FIND IT!! Eric
http://www.Kenji211.com (Kenji is the Man) 11.202@127 1985 Honda Spree (Killin Spree) 1990 Miata (Awaiting 302ci Beast) 2004 Nissan Titan (Bike Hauler) 2000 Civic SI (sold) 1996 HB (Sold) 2003 ZX6R 636 (Track Whore) "Fitness Forum All-Star" |
#20 |
Best way to put it in is to use a channel lock plier. As long as its big enough, you'll get good leverage to squeeze it in. If you can't picture it, I'll try and draw a pic. Let me know how it works out.
Forced to get out.........selling all of my goods. |
#21 |
i hate that "bitch pin" more than anything. i'll pull the motor w/ one main linkage arm. arrg.
#22 |
you can also use a 12mm bolt, like from a throttle body, and tap it in or out with one, fits perfect. When pounding it back in, make sure you have a thin screwdriver or something you can push thru the pin to make sure it is lined up before you start pounding away, sometimes the linkage will move a little and you think it's going in, but it's really just hitting next to the hole in the linkage...
Parts ForSale Updated as of 7/24/09 Billy Mays Tested, Vince Approved! (RIP Billy) |
#23 |
if its mushroomed, shave a little of the mushroomed part off till it fits nicely
i once bit a mans ear off....im not proud of it......but it got me out of many a jam- Harry Carrey |
#24 |
here's a tip. make sure the holes line up
sounds stupid, but i did it after teh first whack it moved, everyother wack just damaged the fit more honda shoulda just stuck a fuggin bolt in there
93 EJ coupe Si, 95 JDM B18C, Greddy turbo kit - 8 Psi, Trust type 31 intercooler, Blitz DD BOV, Walboro pump, Hondata S200 w/boost, Hondata intake gasket, RC 550cc injectors, B&M FPR, NGK BKR7E plugs gapped at .028, Skunk 2 camgears, ACT street clutch, 10 lb OEM flywheel. 188WHP 13.5 @ 105mph Toyo T1S My Ride <FONT COLOR="blue">Still looking for a P54 AC bracket....</FONT> |
#25 |
use a punch tool that will be the same width of the pin.... or u can use the bolt that is used for hooking the header and cat-converter together.. it s the same size as the pin.
| Bookmarks |
