f22b2 (non-vtec) to f22b1 (vtec) wiring
Old 04-04-2003, 01:02 PM
lightningd's Avatar
Default f22b2 (non-vtec) to f22b1 (vtec) wiring
i have a 94 LX auto w/ a f22b2, and swapping to a f22b1 5 spd. (why just to another f22, b/c i autox and want to stay in the same class, not move to street mod).
but anyways, the wiring should be the same for anyone that has done an f22b2 to an h22. how do i wire vtec up? are the wires already in the engine harness? will I have to add wires. and where exactly are they located? and btw, i'm using the f22b1 ECU too.
Old 04-04-2003, 01:30 PM
BustedLX's Avatar
Default Re: f22b2 (non-vtec) to f22b1 (vtec) wiring (lightningd)
You need to gound the Vtec Pressure sensors black wire to a good gound source then run the Vtec Solonoid's green/yellow wire and the pressure sensors blue/black wire into the passenge compartment.
Connect the green/yellow Vtec solonoid wire to the pin A4. It is unused in your harness right now. Harness "A" is the big first harness and pin location 4 is the second slot over on the bottom row. It goes zig-zag pin A1 is a brown wire so A4 is under it to the the right next to the yellow wire (A2)
Connect the Blue/Black pressure sensor wire to pin D6. It is also blank in your stock harness. The D connector is the third connector directly opposite the A connector. There is no C connector in OBD-1.
Remember the pin locations go zig-zag. So it's 1 up and 2 bellow it. So think of it like this odd number are the top row and even are the bottom row. So D6 is three spaces over on the bottom row of the thrid harness.
I hope this wasn't to confusing. If you want email me at email@josebellas.com and I'll try to explain it better.
But that's all you need to do. Good Luck.
stupidhard
05-15-2014 12:33 PM
Jakester9500
12
08-08-2007 05:25 AM
MotoCARR
11
12-21-2006 01:03 PM
blue_hatch
12-18-2006 08:32 PM
rcantu
06-11-2006 01:41 PM
Quick Reply: f22b2 (non-vtec) to f22b1 (vtec) wiring
