The difference in compression between B20B VS B20Z
#176
re: The difference in compression between B20B VS B20Z
i bought my b20b through hmotors. motor looked almost brand new. mated it to a gsr tranny and i loved the setup. i'd give them a call first though to see if they have any b20z's in stock. they're getting hard to come by. also try importautosalvage.com. they might have a 99-00 usdm b20z. same specs as jdm.
#177
Great info. But you need to mention that all of these motors are used, they could have had work done to them, things like cheaper non-honda head gaskets that will change compression, or thicker higher ones, when I ordered a stock b16 a few years back(non lsd) its came with a cusco LSD, I just happened to get lucky. and from what i understand when ever you order a used JDM stuff you always take a risk that internals have been changed, upgraded or even down graded.
#179
Ditto, I notice you are also from the uk. Im guesing the B20B3 is the uk B20b.
I just got one and it has no knock sensor, and the long girrafe intake. IM guessing its 8.8 compression.
IM thinking i will just get replacement pistons and bring it up to somewhere in the region of 11:1CR.
I will be using a vtec head, B16A/a2 or something similar.
I am aiming for 200+ fhp.
#180
hey guess ive read most of the first pages but still un clear of wich cp ratio i have,
i just bought a 99 jdm b20b with long mani and p-75 head no knock sensor , 8.8? 9.2? idk plz help
#181
The 9.2 comes with a p8r head
And the 9.6 cr comes with a knock sensor
#182
i have 99 to 00 jdm b20 with knock sensor. 9:6:1 cr. what numbers can i expect from the motor. trying to build a 12 se. car in the quarter mile what do u suggest. it is sitting in a 94 honda civic ex.
#187
Question i bought a b20b p3f with a p75 head but its has a knock sensor.... Does that make it high compression or a low compression can come with a knocksensor?
#188
Hey my name is Tim thacker and i have a 95 acura integra, and ive been having problems one right after another. So that leads me to this question, im completely tired of f***ing with this motor. Its a b20b in the teggy right now and im actually about to order a new motor tomorrow. Im looking at a b20z to put in it rather than the b20b, would i be able to use the parts off of my b20b and put it on my b20z? Is there a difference between the two? Other than the compression. Please get back with me as soon as possible like i said i would like to order the motor tomorrow please and thanks in advanced for the help!!
#189
#190
Re: The difference in compression between B20B VS B20Z
9,2:1 cr = phk high comp + p8r head ( 47cc combustion chamber and 84mm bore )
P75 head has 45cc combustion chamber and 81mm bore, for this is the 9,6:1
DevinW
09-26-2011 02:33 AM
InfamousRS
09-21-2002 05:59 PM
