Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 03-25-2003, 02:56 PM   #1
crxtreme27
crxtreme27's Avatar
Default What if i dont change my O2 sensor???
For the past two months (about 2k miles)i have been driving around with my check engine light on, which says code 1 (O2 sensor)... will anything bad happen to my engine?? should i not drive the car until i get it fixed??
thanks
89 CRX DX - ZC ~ blown head gasket / bad piston rings
89 hatchback DX - b16a ~ sold
1990 LS Integra
2002 R1
crxtreme27 is offline   Reply With Quote
Old 03-25-2003, 03:12 PM   #2
RCautoworks
Send a message via AIM to RCautoworks
Default Re: What if i dont change my O2 sensor??? (crxtreme27)
Your car will be in limp mode, which if you drive in limp mode for to long I heards it not good. Why not fix it ?
[Modified by 90blackcrx, 6:12 PM 3/25/2003]
RCautoworks is offline   Reply With Quote
Old 03-25-2003, 04:05 PM   #3
Charlie Moua
Charlie Moua's Avatar
iTrader Rating: (2)
Default Re: What if i dont change my O2 sensor??? (90blackcrx)
well honestly my car is in storage and has been driven a total of about 5k with a bad 02 sensor..... no problems.
VOUCH Thread
~ JordanTuned ~ Prodigy Racing Engines ~ 4piston ~ CNC Werx ~ phearable.net
~ Modern Automotive Performance ~ SpeedTrap Turbo Consulting ~ Rocket Motorsports
Charlie Moua is online now   Reply With Quote
Old 03-26-2003, 06:21 AM   #4
RCautoworks
Default Re: What if i dont change my O2 sensor??? (Charlie Moua)
Well I only heard that when you finally get the check engine light fixed, then the engine don't run like its ment to be cause its been running so rich for so long.
[Modified by 90blackcrx, 11:33 AM 3/26/2003]
Old 03-26-2003, 06:42 AM   #5
Blaze45
Blaze45's Avatar
my 02 does the same thing. I just shut the car off then turn it back on, no check engine and no limp mode.
Blaze
F22a F2D Civic build http://jwsparetime.blogspot.com/2011/12/hook.html
Blaze45 is offline   Reply With Quote
Old 03-26-2003, 07:04 AM   #6
ScottEK
ScottEK's Avatar
Send a message via AIM to ScottEK
Default Re: What if i dont change my O2 sensor??? (Blaze45)
If you dont have an o2 sensor working properly then you are never going to have the correct A/F ratio. I believe if there is no signal at all the ECU puts it into limp mode and it runs very rich to prevent a lean condtion. This means you'll get horrible fuel mileage and you'll have to clean up your spark plugs when you do get around to replacing it. Last time I replaced one I used a Bosch universal and just soldered on the plug from my last one, I think the total was $42.00 at autozone.
Scotty Doesn't Know!
90' Chameleon CRX - TopMount SC61 w/ 4" Downpipe Can Be Done...
94' Integra - Project Dadfab
96' Civic EK H22 Hatch
02' RSX Type-S Daily Driver
<FONT COLOR="blue">Download My Turbo CRX Videos</FONT>
ScottEK is offline   Reply With Quote
02, bad, cel, change, dont, drive, fix, happen, o2, oxygen, replace, rsx, sensor, sensors, whats
