Gear ratios:
Old 03-24-2003, 08:22 AM
  #26
DsITR's Avatar
Default Re: Gear ratios: (2point6)
Quicker... not faster.
werd....ahem.
It would "accelerate" faster, but you would lose top end.
[Modified by dsludefosho, 10:22 AM 3/24/2003]
Old 03-24-2003, 08:43 AM
  #27
satan_srv's Avatar
Default Re: Gear ratios: (F20bcivic)
hey my euro-r tranny makes a funny noise too, when i slow down it sounds like its whinding down. is that the same problem? or something else?
[Modified by F20bcivic, 12:04 AM 3/15/2003]
Really Minh? That's interesting to know...yours is an Accord Type-R tranny. I have a Euro-R myself...
Old 03-24-2003, 08:44 AM
  #28
satan_srv's Avatar
I made a mistake on the on the M2A4 tranny gear ratios... They are the same as the M2B4 lsd tranny.
Sorry for the inconvenience
You know that's what I thought! I thought the M2A4 = M2F4 it was just JDM vs. USDM codes for the same tranny.
2point6 you should edit your first post
[Modified by satan_srv, 12:45 PM 3/24/2003]
Old 03-24-2003, 10:42 AM
  #29
Mighty Mintos's Avatar
Default Re: Gear ratios: (satan_srv)
hey joel what the difference between the euro-r and the accord-r tranny?does your tranny make the whining noise too?
Old 03-24-2003, 10:46 AM
  #30
satan_srv's Avatar
I'll have it in in a week mine is brand new so I will know if there is a characteristic sound to it
The only differnce between the two trannies is the ATR (yours) 5th is .870 while the Euro-R 5th (Mine) is 0.812. Here's some pics:
I can go ask on a european board about the gears and if that noise exists.
Other than that how are you liking the tranny? Noticeable improvement in acceleration?
Old 03-24-2003, 01:38 PM
  #31
2point6's Avatar
you know that's what I thought! I thought the M2A4 = M2F4 it was just JDM vs. USDM codes for the same tranny.
There are gearing differences between the USDM trannys and the JDM counterparts. I also had already changed the first post before I made the boldface comment about the correction. Thanks.
Old 03-24-2003, 08:53 PM
  #32
PreludeRacer023's Avatar
DAMNIT you guys!!! GRRR will someone please figure out where my tranny came from?? this is driving me nuts..P2T4...ugh..im lost
Old 03-24-2003, 10:12 PM
  #33
XcreatonX's Avatar
Default Re: Gear ratios: (PreludeRacer023)
yeah i had a question i am goin to put a f22(4th gen s) on my h23 and i want a 4.27 final with a rear gear ratio of 4.266:1
what do i need to get those gears and ratio
thanks
Old 03-25-2003, 12:32 PM
  #34
the acceleration is nice. it helps alot. the difference is very noticeable.
Old 03-25-2003, 01:30 PM
  #35
apexii's Avatar
Good post 2.6! I've always wondered what the FD's are on different models.
Regarding the whine, I know that is a normal after-effect from the FD upgrade.
I'm going to jump to a 4.9 in my ITR.
Old 03-25-2003, 01:53 PM
  #36
satan_srv's Avatar
Default Re: Gear ratios: (apexii)
That's weird because the ATR tranny has just a 4.266 FD
Old 07-29-2003, 12:15 AM
  #37
CD8
CD8's Avatar
sorry to bring back such a old topic guys, but i just found the ratios for my tranny (finally)!!! my tranny is code T2T4 from an accord sir-t (lsd/f20b)
1: 3.285
2: 1.956
3: 1.344
4: 1.034
5: 0.787
R: 3.000
FD: 4.266
Old 07-29-2003, 12:12 PM
  #38
RacingLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 &raquo;</TD></TR><TR><TD CLASS="quote">I believe the Euro R trannies have "straighter cut" gears. This can cause whining as well. This is most likely the case with deceleration. I would not see it as a problem. The whinning of improper gears is much different.</TD></TR></TABLE>
Here is a photo of the gears from my ATR tranny. Can anybody tell from the photo is these are "Straighter Cut" gears or if the syncros are beefed up.
Old 07-29-2003, 01:17 PM
  #39
satan_srv's Avatar
Default Re: Gear ratios: (CD8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD8 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to bring back such a old topic guys, but i just found the ratios for my tranny (finally)!!! my tranny is code T2T4 from an accord sir-t (lsd/f20b)
1: 3.285
2: 1.956
3: 1.344
4: 1.034
5: 0.787
R: 3.000
FD: 4.266
Yup that's what I've been saying all along the T2T4 is just a 5th gen tranny with LSD...nothing special about the gears.
Old 07-29-2003, 01:18 PM
  #40
satan_srv's Avatar
Default Re: Gear ratios: (RacingLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacingLude &raquo;</TD></TR><TR><TD CLASS="quote">
I have a Euro-R tranny. It's not straight cut you would be able to hear it. And the synchros are not beefed up, my 5th gear already grinds and it has only 7,000 miles on it.
Old 07-29-2003, 01:40 PM
  #41
CD8
CD8's Avatar
ATR, and Euro-R are two different cars, with two different transmission. but you already knew that
Old 07-29-2003, 02:04 PM
  #42
poison's Avatar
Euro R H22A (T2T4)
1st - 3.285
2nd - 2.090
3rd - 1.481
4th - 1.071
5th - 0.812
FD - 4.266
Accord Type-R (U2Q7).
1st - 3.285
2nd - 2.090
3rd - 1.481
4th - 1.071
5th - 0.870
FD - 4.266
[Spec-s is 5th gen ratio with LSD]
Old 07-29-2003, 02:50 PM
  #43
2point6's Avatar
I updated the original post.
Old 07-29-2003, 02:57 PM
  #44
RacingLude's Avatar
" I have a Euro-R tranny. It's not straight cut you would be able to hear it. And the synchros are not beefed up, my 5th gear already grinds and it has only 7,000 miles on it."
What kind of transmission fluid are you using? I using Redline MTL. I've heard a few bad things about it though.
Old 07-29-2003, 04:05 PM
  #45
CD8
CD8's Avatar
Default Re: Gear ratios: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Euro R H22A (T2T4)
1st - 3.285
2nd - 2.090
3rd - 1.481
4th - 1.071
5th - 0.812
FD - 4.266
1st - 3.285
2nd - 2.090
3rd - 1.481
4th - 1.071
5th - 0.870
FD - 4.266
</TD></TR></TABLE>this still isnt correct, because i know someone w/ a complete euro r swap in their accord and his tranny code is T2W4. my tranny is code T2T4 and is form an Accord Sir-t from japan also. the euro r and sir-t are from japan, the ATR is from europe.
Old 07-29-2003, 04:25 PM
  #46
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD8 &raquo;</TD></TR><TR><TD CLASS="quote">this still isnt correct, because i know someone w/ a complete euro r swap in their accord and his tranny code is T2W4. my tranny is code T2T4 and is form an Accord Sir-t from japan also. the euro r and sir-t are from japan, the ATR is from europe. </TD></TR></TABLE>
Actually, the original information I had the original tranny code was T2W4, I just had thought it was a typo and corrected it for T2T4, because I thought it was wrong.
I wasn't exactly sure. My bad lol.
Old 07-29-2003, 05:44 PM
  #47
CD8
CD8's Avatar
oh its all gravy just so much different info to keep track of out of jay dee em land!
str8rcn
11-20-2015 03:45 PM
kornerk12
09-22-2006 08:39 PM
GReddySiR
08-18-2004 12:05 AM
iakona
09-24-2003 05:26 PM
Francois
08-14-2002 07:20 AM
Quick Reply: Gear ratios:
