#1 | |||||
97 2.2 CL F22B1 253 hp/264 ftlbs One cam...not two http://home.insightbb.com/~niedejb |
#2 |
Really Good Post
I have a question, does the EGR gases still get to flow on the intake on the left part? meaning, does it still heats the IM? or did you block that on the head?
Really good exhaust thread "people too weak to follow their own dreams will always find a way to discourage others." Taken from CRXDX http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif "Love is the best disease a human can have" -Me |
#3 |
It still gets to the valve.
I'm more worried about crap getting into my brand new engine than the manifold heat. If you block it at the head the gases wont lift the valve (I think) and youll get a CEL. I havnt tried that, but my feeling is it wont work. The ECU can detect the solenoid not working and the actual lift on the EGR valve. Vac ought to raise the valve, but all these EGR CEL posts say that cleaning these ports solved the problems. If thats the case, the vacuum alone couldnt pic up the valve all the way. Either that or the build up inside the valve kept it from raising all the way.
#4 | |
why would one do this? disabling egr what are the advantage of doing so ?
MY HondaSociety.com VOUCHE THREAD !! MY <FONT COLOR="black">HONDA-</FONT><FONT COLOR="blue">TECH.com</FONT> VOUCHE THREAD !! http://images.honda-tech.com/set1/smile/emthup.gif http://images.honda-tech.com/set1/smile/emthup.gif Quote:
#5 | |
BTW, removing the entire manifold would be required for blocking where you are describing (pain in the ass). The way I posted can all be done with the intake manifold in place.
#6 | |
1) These passages clog over time and could cause a CEL. 2) These gases dilute your intake charge and rob you of power (minimal but still a loss) 3) Tuning air to fuel ratios would be a pain in the ass if this valve is diluting some of the time and not the others. The exaust gasses can increase/decrease the likelyhood of detonation when boosting.
#7 |
Can't you block off all the holes and not throw a cell since you're going to be using the AEM system?
i need to block off everything and take out that ugly egr valve to use my fuel setup.... i've unplugged the whole EGR system... so far no cell with the OBD I
1994 Accord Coupe EX 5spd 269 whp/ 281wtq @ 14psi stock engine with boost leak lol and now 0whp / 0wtq @ -1 psi... http://images.honda-tech.com/set1/smile/emsad.gif http://www.honda-tech.com/zerothread?id=814922 the original accordfreak. all others are copies |
#8 | |
I'm running the stock ECU for the break in and didnt want the contamination until I get the EMS in and tuned.
#9 |
Excellent post!
i wonder how hard it would be to make a heat sink type setup to bracket on to the egr valve to dissipate the heat?
-James 92 Civic HB Torch Red 96 Toyota Tacoma 2WD Viper GTS Blue Metallic |
#10 | ||
You'd be better off spending time & effort on something that looks more like a charge cooler. Or a CAI.
JimBlake '03 Accord & '07 Civic '01 Saab 9³ & '05 9²x TECHNICAL(?) quote... Quote:
#11 | |
so it wouldnt be that big of a factor.
#12 |
Good Post..... may have to check that with my engine before i do the smog
"expletive what you think, i'll still out handle you" <----1995 Accord EX Coupe (CD7) PAYPAL VERIFIED My Vouches: Bigxclumzy,TheBEeGuY,FF-Greg,FF-Sean, FR-MOB: The B33 Gay,DUFFM4N, Shelton, Freaker, 91CrXB16a, 88crxkidsir (Los), donut, and more just can't remember names http://images.honda-tech.com/set1//smile/emcrook.gif |
#13 |
neidejb, what happen to your old motor? still gonna boost it?
Honda s2000 Ap1 00' Silverstone(153lb-ft of torqueless wonders) Mazda Miata Mx-5 90' BMWjetblack(116hp of ball-less fury) |
#14 | |
#15 |
Hey I bought a 91 Accord SE with a blown engine. I dropped a 94 F22B2 in it with the head from the 91. Here are some of the problems I'm having. Engine light is on, S light flashes, wont shift into overdrive, engine revs up & down. Codes 12 & 17 flash meaning EGR & speed sensor problems. I've changed the Speed sensor, still same problem. I believe my problems are electrical but I'm not sure.
Question is where do I start? Do I change the ECU to a 94? Could it be the TCU? I've put way more money into this than I wanted already, when should I stop? |
#16 |
H-T Order of Merit
that is a question that is completely unrelated to this thread.
Please create a new thread to discuss your problem(s). Thanks |
#17 |
Beautiful write up
#18 |
Nice write up !!!
#19 |
Can you rehost the pictures? I only see red x's
#20 |
can i block of the egr on my 96 accord ex f22b1?
obdll and i will need to get emissions this summer. i can always unclog it for emissions the pics are broken links but im guessing all you gotta do a fab a block off plate and use some sealer to seal it down over where the egr valve would be. would it be best to just make a block off plate and put the egr vavle back on with the plate underneath it? after doing this what do you do with the vacuum hoses going to the egr valve? |
#21 |
help, why is it i cant see the pictures?
#22 |
great post, thanks
#23 |
1995 Honda AccordJoin Date: Jun 2007
This would create a mean pressure I would think in the head. And also make your engine so dirty and contaminated inside. This is cheap. What you should really be doing is installing an oil catch can to catch the contaminants instead of blocking them and forcing it to stay in the head. Dumb IMO
#24 |
This wouldn't cause any pressure difference in the head. The exhaust gas recirculation system works off vacuum from the intake. As the EGR valve opens, the vacuum created by the intake manifold pulls exhaust gases into the intake system. Through a small opening in the left exhaust port on the #4 cylinder.
An oil catch can is used in line with the PCV system to catch any oil and carbon from getting into the intake manifold not exhaust gases. However I still think that this mod will throw an insufficient exhaust gas flow CEL after a while. You may not get the EGR lift CEL but insufficient flow should still be detected. Last edited by GhostAccord; 06-22-2009 at 06:37 PM. |
| Bookmarks |
| Tags |
| 2000, ap1, block, blocked, civic, diable, disable, disabler, egr, engine, happen, honda, miata, passage, system, unclog, valve |
