Vents Only blows HOT air
Old 03-09-2003, 10:43 AM
B18C1 '96 Coupe's Avatar
Default Vents Only blows HOT air
What makes vents only blow hot air. I change the slider to cold and its still hot. No matter what I do I cant get it to blow cold. Is their anything you all can think of that might help me out at all? Is there anything vacum wise that way cause this?
Old 03-09-2003, 10:50 AM
xXTypeONegativXx's Avatar
Default Re: Vents Only blows HOT air (B18C1 '96 Coupe)
compressor
Old 03-09-2003, 10:53 AM
Nine's Avatar
Maybe they took out the AC when they installed ur b18c and forgot to tell you about it.
Old 03-09-2003, 11:00 AM
Default Re: Vents Only blows HOT air (Nine)
The AC is out. But shouldnt I be able to still blow cold air? and If not what do I need to make it blow cold air not aC just cool air.
Old 03-09-2003, 11:08 AM
Nine's Avatar
LOFL! I was kidding when I said that.. Im pretty sure you can't blow cold air w/o an AC once the car gets warmed up, unless you ghetto rig something.
Old 03-09-2003, 11:17 AM
How do non A/C cars blow cold air. I dont want like a frigid air just colder air.
Old 03-09-2003, 11:24 AM
FifthGearOnline's Avatar
sounds like tour control's are shot...
understands what you are saying
Old 03-09-2003, 11:33 AM
slooowDX's Avatar
Default Re: Vents Only blows HOT air (FifthGearOnline)
control valve is stuck open, check by the firewall where the heater hoses go through, make sure whoever did the swap didnt mess up the linkage that controls the valve
Old 03-09-2003, 11:46 AM
Default Re: Vents Only blows HOT air (slooowDX)
Thanks Thats what I needed. I will check that tonight
Old 03-09-2003, 11:51 AM
Nine's Avatar
Maybe I am misunderstanding your question but once I took out my AC, it would never get any colder then the outside temperitures..
Old 03-09-2003, 12:01 PM
Thats all I want. It blows hot air like winter time. Sucks now that it is heating up though. Jsut roll around rolling the windows up and down to control the inside temp sucks.
Nytrious
09-05-2013 02:32 AM
niceprelude
06-02-2011 01:08 PM
hondaracin24
02-27-2006 06:10 PM
abeaujuin
05-09-2004 08:18 PM
Quick Reply: Vents Only blows HOT air
