No voltage on 12v constant wire
Old 03-04-2003, 04:37 AM
Bigjon
Guest
Posts: n/a
Default No voltage on 12v constant wire
I tore an old alarm out of my car and now I dont have any voltage on the memory wire for the radio. When the car is off there is like .4v on it and when the car is running there is like 4v. I trace the wire to the fuse box. It isnt shorted to ground and all my fuses are good. BTW the car is a 93 civic. Maybe i am missing something obvious. can anyone shed some light on this for me. thanks
Old 03-04-2003, 07:07 AM
koco's Avatar
Default Re: No voltage on 12v constant wire (Bigjon)
Gee whiz! I have the same problem with my 94 Civic. I had to grab power from a different place, after giving up trying to find out why. I never posted that one here though.
Old 03-04-2003, 07:26 AM
rjr162's Avatar
Default Re: No voltage on 12v constant wire (koco)
i saw this happen to a 98 civic with the factory radio. The radio "wasn't working" and they wanted a new one put in. Did that, still didnt' work. Here the accessory was at 5v's and not 12. Odd
Old 03-04-2003, 09:15 AM
HatchAttack242's Avatar
Exact same thing happening with my 93 DX hatch.. only 4 volt coming across.. ended up running a wire from the battery.. This seems like a very common problem. Hopefully, someone will have the answer.
Old 03-04-2003, 10:41 AM
Bigjon
Guest
Posts: n/a
Default Re: No voltage on 12v constant wire (HatchAttack242)
I think that is what I will end up doing. But I am gonna run a wire from the battery to a fuse box that I am gonna add to power the radio, power locks and alarm. It just bothers me know that that wire isnt working and i cant find out why
Old 03-04-2003, 05:06 PM
tvrvic's Avatar
my friends 92 vx hatch had the same problem too, how weird, ran a new power wire from the battery to fix it. don't forget to fuse it too. wonder what causes this?
Old 03-04-2003, 09:26 PM
Brett's Avatar
Default Re: No voltage on 12v constant wire (tvrvic)
I had the same problem in my 97 integra. No power to the constant radio wire so I ran my own from the battery. Turns out there is a fuse called "Backup" in the fuse box under the hood. Doesn't say anything about radio on the fuse chart.
HTH
Old 03-04-2003, 09:45 PM
twogengsr's Avatar
Default Re: No voltage on 12v constant wire (Brett)
you all have the same problem it is the brown 7.5 amp fuse UNDER the hood that says back up replace that fuse and all your 12v will return to that wire
Old 03-05-2003, 02:52 AM
Bigjon
Guest
Posts: n/a
Default Re: No voltage on 12v constant wire (twogengsr)
So anyways that fixed it. Thanks for the help. Finally after two months of not haveing anythign to listen to besides the sqeeks of my chassis.
[Modified by Bigjon, 9:28 PM 3/6/2003]
Old 03-05-2003, 07:08 AM
rjr162's Avatar
Doh! I was just about to came back to this post and say that. I forgot to mention I've seen that happen a few times. The fuse blows, but not completely, so your voltage drops. I've seen an inline for an amp drop from 12 to .3v
Old 03-06-2003, 09:44 PM
koco's Avatar
Sho nuff she's blown captain. 7.5 amp backup fuse just like you said. I guess I shorted the wire while changing radios.
j.packsb
Audio / Security / Video
03-08-2010 03:32 PM
redsled00
04-10-2009 10:17 PM
kp
03-27-2009 11:18 AM
2DoorBandit
05-07-2006 07:48 PM
Stryker908
05-26-2003 03:31 PM
Quick Reply: No voltage on 12v constant wire
