Where the hell is the MES connector??????
Can someone please put up a pic or give a detailed explanation of where exactly the mes connector is on a 95 EX? Please, there so many conflicting descriptions. It is definitely a two prong connector correct? Please help.
Re: Where the hell is the MES connector?????? (lahight)
If you're reffering to the service jumper (to check codes, set timing etc) on most 5th gens I've seen that is below the glove box usually in a little blue holder (unless you've had it out before and just left it hanging). If thats not what you're looking for please clarify and I'll try to help!!
[Modified by GimpyAccord, 5:15 PM 3/1/2003]
1 Post
Re: Where the hell is the MES connector?????? (GimpyAccord)
yes, gimpy is right. its under the glovebox, in another connector. just look up in there and pull it out. its only a 2 wire plug.
No, he's after the memory erase signal (MES) connector. It's used for eraseing SRS codes. It's on the left side of the dash near the fuse box. It will have either two gray wires, or one black wire and one white wire.
Re: Where the hell is the MES connector?????? (Chiovnidca)
Funky!!!! and now I know.
no SRS equiped accord unfortunatly in my garage... or fortunatly that is.
anyone have any pics or a more detailed description, i have been breaking my damn neck under there and i cant find it
1 Post
Re: Where the hell is the MES connector?????? (D16Chiovnidca)
Here you go...
MES 90-97 Accord at right bottom edge of dash.
[img]c:\mes.jpg[/img]
Here's the URL http://alflash.narod.ru/honda.htm
[Modified by subnet, 2:40 PM 3/5/2003]
[Modified by subnet, 9:01 PM 3/5/2003]
94CoupeEJ1
14
01-01-2013 01:59 AM
