my car won't turn over and it's not the battery, *Please Help*
Old 02-28-2003, 01:19 PM
junya16's Avatar
Default my car won't turn over and it's not the battery, *Please Help*
so last night i started driving my car and at about 3500 rpm's in first it felt like it wasn't gettin any fuel and was sluggish but ran ok the rest of the trip. then when i went to start it again it would turn over but even when i tryed to jump it it wouldn't start. now it just doesn't even turn over and i checked the fuel pump and line and they are ok and put a new battery in and that did nothing. any suggestions?
Old 02-28-2003, 02:16 PM
tominos's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (junya16)
so it doesn't even crank? could be your starter, but that doesn't explain the sluggishness
Old 02-28-2003, 02:26 PM
pennies_hatchie's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (tominos)
i have to agree with the starter...
just hit it a couple of times and have someone inside try to start it to see if turns over.
Old 02-28-2003, 02:28 PM
BangAccord's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (pennies_hatchie)
I also think it's the starter
Old 02-28-2003, 02:53 PM
junya16's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (BangAccord)
i tested the starter and it was fine, it cranked over fine last night and still no luck but today it's not even turning over and by the test the starter is supposedly ok.
Old 02-28-2003, 06:13 PM
Dr. Gonzo's Avatar
Make sure all cabels to starter are tight...I recently changed my clutch and I didn't do what i just sugested. I had problems starting and it was all because the main power cable to the starter was loose.
-ben
Old 02-28-2003, 06:14 PM
All_Lag's Avatar
it could be a number of things
-Broken, loose or disconnected wiring to the starter
-Starter motor pinion jammed in flywheel ring gear
-Bad Ignition
-Starter pinion or flywheel teeth worn or broken
Old 03-01-2003, 05:40 PM
junya16's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (SlowSOHC)
it was the coil in the distributor, never would have guessed but glad to have it fixed
Old 03-01-2003, 06:50 PM
1SlowB16EF's Avatar
did you ever test the battery or just going by the fact that it wouldnt start on the jum start... it might not have been giving enough power through the jump to start it ....
Old 03-01-2003, 07:30 PM
junya16's Avatar
Default Re: my car won't turn over and it's not the battery, *Please Help* (1SlowB16EF)
the battery was bad but it would have worked if the coil would have been fine. but i got a new battery anyway
Matt S.
01-31-2016 11:24 AM
jorge59la
09-16-2007 06:28 PM
deftones0817
07-14-2005 08:17 AM
alfee
04-04-2005 07:03 PM
ahcjar103
12-09-2001 11:37 PM
Quick Reply: my car won't turn over and it's not the battery, *Please Help*
