Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 02-20-2003, 11:45 PM   #1
AVXHATCH
AVXHATCH's Avatar
Default Whats the difference between the 88-91 crx hf, and the crx dx??
Just curious, because i originally wanted the hf, but i mighta found a good deal for the dx, whats the difference between the two?? Is the dx fuel injected?? would it be bad to buy the dx?? thanks
Īts not how you stand by your car, its how you race your car, you better learn that"
[img]http://images.honda-tech.com/set1/smile/emsmilep.gif[/img]
AVXHATCH is offline   Reply With Quote
Old 02-20-2003, 11:56 PM   #2
Vinceg99
Vinceg99's Avatar
Default Re: Whats the difference between the 88-91 crx hf, and the crx dx?? (B16A6rex)
Well the HF is MPFI and the DX is DPFI. So if your planning on doing a swap expect some extra wiring to convert it form DPFI to MPFI not very hard but a bit more work. The HF is also lighter than the DX. What are your plans for it?? You could pick up the DX and do a MPFI swap on it right away that will put you to about the same amount of power as the Si. If your not planning a motor swap I would say get the DX if your going to do a swap then go with the HF it will be less work and headaches in the long run.
Vinceg99 is offline   Reply With Quote
Old 02-21-2003, 12:01 AM   #3
crex23
crex23's Avatar
Send a message via AIM to crex23
All CRX's 88 and up are fuel injected. The HF is the slowest, but also the lightest. A good candidate for a race car provided that you swap the engine Click the image to open in full size. The HF came from the factory with about 70-75 HP. The DX has about 80-85 HP. The HF lacks alot of accessories like rear wiper, A/C, rear cargo covers, etc. that the DX has. Hope this helps.
89 CRX DX - auto SOHC ZC
88 CRX HF - built LS turbo
98 Integra LS - daily grind
crex23 is offline   Reply With Quote
Old 04-28-2004, 11:14 AM   #4
urquidezj
urquidezj's Avatar
Default Re: Whats the difference between the 88-91 crx hf, and the crx dx?? (crex23)
so the zc blacktop dohc swap would be a sinch? or what is needed?
urquidezj is offline   Reply With Quote
Old 04-28-2004, 11:22 AM   #5
EL Vap133
EL Vap133's Avatar
Send a message via AIM to EL Vap133
Not true, my dx does not have AC or a rear wiper. But it did come with a complete rear interior. Also, the HF has a blue interior, my DX has black interior. The DX seats are nicer looking than the HF seats too. Click the image to open in full size.
WTB: 96-00 Civic EX/Si, catalytic converter.
EL Vap133 is offline   Reply With Quote
Old 04-28-2004, 01:55 PM   #6
Sampsonite987
Sampsonite987's Avatar
Default Re: Whats the difference between the 88-91 crx hf, and the crx dx?? (EL Vap133)
Depending on how hard it is to find a rex in your neck of the woods, I know it is difficult to find one in decent condition where I live. I would go with the HF, I just recently picked up an HF and the Si swap was extremely simple. But it all depends on what you plan to do with it. Click the image to open in full size.
I want some Rass-Bury iced tea.
Sampsonite987 is offline   Reply With Quote
88, 8891, civic, crx, difference, differences, dx, engine, fuel, hf, injected, injection, seats, si, standard
