TECH: 5th Gen OBDII ECM/PCM Terminal Arrangement
Old 02-11-2003, 06:40 PM
carolinaACCORD's Avatar
Default TECH: 5th Gen Accord OBDII ECM/PCM Terminal Arrangement
I know some people wanted this, so I'm posting it up.
This is straight out of the factory service manual.
***Some wires may be the same color on the same connector, so also go by pin position. Pin position goes from left to right, top to bottom; looking at the connector with the latch side up.***
***Column 1 is wire color--->column 2 is terminal name***
<U> Connector A (32P) </U>
YEL---&gt;INJ4 (#4 FUEL INJECTOR)
BLU---&gt;INJ3 (#3 FUEL INJECTOR)
RED---&gt;INJ2 (#2 FUEL INJECTOR)
BRN---&gt;INJ1 (#1 FUEL INJECTOR)
ORN/BLU---&gt;SO2SHTC (secondary heated O2 sensor heater control)
ORN/BLK---&gt;PO2SHTC (primary heated O2 sensor heater control)
RED---&gt;ESOL (egr control solenoid valve)
GRN/YEL---&gt;VTS (VTEC solenoid valve) *3
BRN/BLK---&gt;LG1 (logic ground)
BLK---&gt;PG1 (power ground)
YEL/BLK---&gt;IGP1 (power source)
BLK/BLU---&gt;IACV (idle air control valve)
GRN/WHT---&gt;MCS (engine mount control solenoid valve) *4
RED/YEL---&gt;PCS (evap purge control solenoid valve)
GRN/BLK---&gt;FLR (fuel pump relay)
RED/BLU---&gt;ACC (air conditioning clutch relay)
LT. GRN/RED---&gt;MIL (malfunction indicator lamp) (a.k.a., CEL)
WHT/GRN---&gt;ALTC (alternator control)
YEL/GRN---&gt;ICM (ignition control module)
BRN/BLK---&gt;LG2 (logic ground)
BLK---&gt;PG2 (power ground)
YEL LT BLK---&gt;IGP2 (power soure)
ORN/GRN---&gt;IAR SOL (intake air resonator control solenoid valve)
GRN---&gt;FANC (radiator fan control)
GRN LT WHT---&gt;2WBS (evap bypass solenoid valve) *1
ORN/GRN---&gt;VSV (evap control canister vent shut valve) *1
<U> Connecotr B (25P) FOR AUTOMATICS ONLY </U>
BLU/YEL---&gt;SHA (shift control solenoid valve A)
GRN/BLK---&gt;LC B (lock-up control solenoid valve B)
YEL---&gt;LC A (lock-up control solenoid valve A)
GRN/BLU---&gt;ATPD3 (a/t gear position switch)
GRN/WHT---&gt;SHB (shift control solenoid valve B)
WHT/GRN---&gt;ILU (interlock control unit)
BLU/RED---&gt;D4 IND (d4 indicator light)
WHT/BLU---&gt;NMSG (mainshaft speed sensor ground)
ORN/BLU---&gt;NM (mainshaft speed sensor)
GRN/RED---&gt;ATPR (a/t gear position switch)
GRN/YEL---&gt;ATP2 (a/t gear position switch)
LT. GRN/WHT---&gt;ATP1 (a/t gear position switch)
BLU/YEL---&gt;NCSG (countershaft speed sensor ground)
BLU/GRN---&gt;NC (countershaft speed sensor)
LT. GRN/BLK---&gt;ATPD4 (a/t gear position switch)
LT. GRN---&gt;ATPNP (a/t gear position switch)
<U> Connector C (31P) </U>
BLU---&gt;CKPP (crank position sensor side)
GRN---&gt;TDCP (top dead center sensor side)
YEL---&gt;CYPP (cylinder position sensor side)
RED/WHT---&gt;ACS (a/c switch signal)
BLU/RED or BLK/GRN on m/t---&gt;STS (starter switch signal) *1
RED---&gt;SCS (service check signal)
LT. GRN---K-LINE (sends and recieves scan tool signal)
WHT/YEL---&gt;VBU (voltage back up)
WHT---&gt;CKPM (crank position sensor m side)
RED---&gt;TDCM (top dead center sensor m side)
BLK---&gt;CYPM (cylinder position sensor m side)
GRN---&gt;PSPSW (power steering pressure switch)
WHT/RED---&gt;ALTF (alternator fr signal)
ORN---&gt;VSS (vehicle speed sensor)
BRN---&gt;PFSW (evap purge flow switch) *2
<U> Connector D (16P) </U>
RED/BLK---&gt;TPS (throttle position sensor)
RED/WHT---&gt;ECT (engine coolant temperature sensor)
WHT/YEL---&gt;MAP (manifold absolute pressure sensor)
YEL/WHT---&gt;VCC1 (sensor voltage)
GRN/WHT---&gt;BKSW (brake switch)
WHT/RED---&gt;PHO2S (primary heated O2 sensor 1)
RED/YEL---&gt;IAT (intake air temperature sensor)
WHT/BLK---&gt;EGRL (exhaust gas recirculation valve lift sensor)
YEL/BLU---&gt;VCC2 (sensor voltage)
GRN/BLU---&gt;SG2 (sensor ground)
GRN/WHT---&gt;SG1 (sensor ground)
RED/WHT---&gt;SHO2 SG (secondary heated O2 sensor, sensor 2 ground)
WHT/RED---&gt;SHO2S (secondary heated O2 sensor, sensor 2)
GRN/RED---&gt;PTANK (fuel tank pressure sensor) *1
GRN/RED---&gt;EL (electronic load detector)
*1: Sedan KA (EX), KL (DX, LX w/ABS, EX), KC (EXR), Coupe models
*2: Sedan KA (DX, LX), KL (LX w/o ABS), KC (LX,EX), Wagon models
*3: F22B1 engine
*4: A/T
If there are any questions IM me.
[Modified by carolinaACCORD, 10:46 PM 2/11/2003]
Old 02-12-2003, 04:23 AM
Stew Pidasso's Avatar
Default Re: TECH: 5th Gen Accord OBDII ECM/PCM Terminal Arrangement (carolinaACCORD)
Great info! Does this apply to OBD I (94-95) Accords as well? Where did you find this info??
Old 02-12-2003, 05:13 AM
Default Re: TECH: 5th Gen Accord OBDII ECM/PCM Terminal Arrangement (Stew Pidasso)
im sure a lot of it is the same for obdI, this came from my helms book.
Old 02-12-2003, 05:17 AM
Ok I have the helms for my car (94) and I couldn't find this info anywhere in it. There is no index. What section/heading do you look in. BTW, I also have the helms electrical supplement and I haven't seen it in there either.
Old 02-12-2003, 05:23 AM
in your service manual, its in the fuel systems section (the section with the fuel nozzle thingy). at the very beginning of that section, there is a table of contents for that section. Look for something like ECM Terminal Arrangement.
when you find it, please look over it and post any differences there may be if you dont mind.
Powered By Garrett
03-30-2008 08:44 AM
slorex
08-31-2005 09:42 AM
unicorn28
03-21-2004 11:37 PM
preeeluder
08-07-2003 09:10 PM
90civic-racer
04-01-2003 04:34 PM
Quick Reply: TECH: 5th Gen OBDII ECM/PCM Terminal Arrangement
