lugnuts - acorn or conical (tapered)
Old 02-08-2003, 11:51 PM
tilt's Avatar
Default lugnuts - acorn or conical (tapered)
I've done a search but it wasnt very helpful.
I know stock honda/acura rims use acorn seating. But do all aftermarket rims use conical / tapered lugs? I just got some Buddy Club P1 SFs and I want to make sure I get the right type. Can someone please explain how you know which one your rims need? And can you recommend any particular brand or style? tia.
Old 02-09-2003, 03:36 AM
CRXGSR's Avatar
Default Re: lugnuts - acorn or conical (tilt)
You just look at where the nuts touch the rim. If that spot has rounded edges, then use acorn nuts. If you see it in the shape of a cone (slants) then use conical.
Old 02-09-2003, 10:24 PM
tilt's Avatar
Default Re: lugnuts - acorn or conical (CRXGSR)
Can anyone recommend some decent conical lugs?
Old 02-09-2003, 10:41 PM
Volcom's Avatar
I use gorilla locking tapered lugs and they work fine.
Old 02-10-2003, 08:00 PM
tilt's Avatar
Default Re: lugnuts - acorn or conical (Volcom)
Can someone please look at the 2nd pic in the link and tell me if those rims should use tapered or acorn lugs? tia
http://cgi.ebay.com/ebaymotors/ws/eB...category=33748
Old 02-10-2003, 09:44 PM
Volcom's Avatar
Most aftermarket wheels require tapered or "tuner style" lugs. OEM is the only wheel I know that uses acorn. HTH
Old 02-11-2003, 09:54 AM
Solo.Rex's Avatar
most everything i have seen is what Volcom said
Old 02-11-2003, 10:23 AM
BROOD's Avatar
Default Re: lugnuts - acorn or conical (Solo.Rex)
The pic is not the clearest but I'd say it uses a tapered (conical) seat lugnut. Gorrila spline lock lugs are great..plus you can get them in black.
SunriseSunset
Honda Civic (2001 - 2005)
17
04-23-2017 09:54 PM
redlinexd
12-15-2008 09:31 PM
freddysEF
07-18-2007 09:03 PM
IntegraBoy04
03-30-2004 07:52 AM
DA9RsIntegra
01-12-2004 02:14 AM
Quick Reply: lugnuts - acorn or conical (tapered)
