What does "spin a bearing" mean?
#27
correct me if im wrong, but the 10 psi rule only works with a 5w20 oil, I THINK.
I KNOW
when im gunning 4 grand to 3,500 on the interstate in my car its right on 60 but that IS with 10w30 oil
i think the different weights of the oil changes the PSI it runs at.
not 100% sure just read it somewhere.
I KNOW
#28
no they dont spin with the crank... the bearings will also stay seated with the in the cap/block or the cap/rod... when u spin a bearing what it essentially does it get thinner... now u have a gap so everytime the crank rotates u now hear a "knocking noise" which is lets say if u spin a rod bearing... its the rod actually bouncing up and down on the crank as it spins
#29
you are correct, but the term "spun bearing" is used so loosley... Someone refering to a "spun bearing" could have excessive bearing wear and what probably should be refered to as a "rod knock", but I don't ASSume anything.
Wes V had the best and most proper answer.
On a ligher note, this thread is funny!
#31
Re: What does "spin a bearing" mean?
I figured this thread was worthless without pics of said spun bearings.
Here is a couple from a 3SGTE engine before I built it. This one in particular did spin in the connecting rod. The piece at the bottom is half a bearing. These are the only pieces I have. I just threw the rest away this weekend but it was carnage. Every single bearing was either smashed or broken. the crank on #4 was also worn away to .03"
Here are few engine building tips to help prevent a spun bearing.
- Cleanliness. Build the engine in as clean an area as possible. There is a reason factory/high end engines are built in clean rooms.
- Build the engine slightly loose and pay attention to torque specs.
- Dont damage the crank when installing the pistons/rods.
- Always replace the water and oil pump.
