Can Z rated tires be patched or plugged and still be safe?
Old 01-27-2003, 10:54 PM
sjracer's Avatar
Default Can Z rated tires be patched or plugged and still be safe?
my friend had a flat tire today...he had his Z rated Bridgstone Potenzas (sorry for the bad spelling) that came stock on his '01 IS300 plugged...
i remebered reading a post on this board that Z and Z+ ratted tires should never be plugged or patched because it is unsafe...is that correct?
something about the tire compound being too soft...
of course it's not the sidewall that got repaired but the tread of the tire...
I did a search and nothing came yup...thanks
Old 01-28-2003, 05:23 AM
JimBlake's Avatar
Default Re: Can Z rated tires be patched or plugged and still be safe? (sjracer)
I believe if the tire is repaired, it loses its "Z" rating. I guess if your friend goes 150mph & the tire blows up, Bridgestone has an excuse for not honoring their warranty?
Old 01-28-2003, 06:19 AM
smokin rubber's Avatar
Default Re: Can Z rated tires be patched or plugged and still be safe? (JimBlake)
Correct, the tire can be plugged, but the it no longer has a high speed rating.
Old 01-28-2003, 06:39 AM
BROOD's Avatar
Default Re: Can Z rated tires be patched or plugged and still be safe? (smokin rubber)
Always patch repair....internal patch.
Never use plugs to repair a tire.....I'd only plug tires if it were temporary and the only available option at the time. Plugs eventually cause more problems than you started with.
Never perform any repair (inculding internal patch) on the sidewall, only replair the tread/crown area.
[Modified by SLPR, 7:52 AM 1/28/2003]
Old 01-28-2003, 08:33 AM
TheOne's Avatar
Default Re: Can Z rated tires be patched or plugged and still be safe? (SLPR)
just curious but how many of ya'll that just posted, work for discount tire or have worked for discount tire?
Old 01-28-2003, 09:29 AM
T04-Terror's Avatar
i dont work for discount tire but i do work for national tire and battery. the best type of patch is a patch/plug. it patches the hole from the inside while at the same time plugs it up. works great and is guaranteed to hold for the life of the tire. also the speed rating mainly describes the thickness of the sidewall. putting a patch in the tire wont lower the speed rating.
Old 01-28-2003, 10:43 AM
sjracer's Avatar
Default Re: Can Z rated tires be patched or plugged and still be safe? (T04-Terror)
okaie...from what i'm understanding is your guy's general consensus...a Z or Z+ rated tire can be repaired on the tread but it will lose its speed rating...
plugs should only be temporary and patches should be used for a some what permanent fix...
is this correct?
Old 01-28-2003, 11:53 AM
BROOD's Avatar
is this correct?
Yep, that sounds about right. Although I have internally patched quite a few track tires that took alot of punishment without any problems after being repaired. I can think of a set of Kumho Victors on a Camero SS that ran tracktime on patched tires and he had no problems. Hmmm
[Modified by SLPR, 12:54 PM 1/28/2003]
cilvia
09-02-2013 01:51 PM
professorman
11-17-2004 10:56 AM
preluder
04-21-2003 09:19 AM
Kengs
11-07-2001 01:51 PM
Quick Reply: Can Z rated tires be patched or plugged and still be safe?
