Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 01-19-2003, 05:51 PM   #1
Jamison
Jamison's Avatar
Send a message via AIM to Jamison
Default align bore questions...
I wanted to know if it is absolutly neccasary to do an align bore on a block that has just been resleeved?
See my problem is that when I was taking apart my block I threw all of the crank supports away, thinking that if I sold it, someone else can use theres when reassembling the block. The gentleman that I was going to sell my b18a block to this weekend, told me that if you throw away the main caps then the block is trash, you cant use it.
My buddy that was with me told me differant and said that you can use any main caps from any b18a on any other b18a block. Also that if you are going to resleeve a block (which this one HAS to be resleeved) it is absolutly neccesary to do an align bore on it.
I dont know who to believe. I posted this here because alot of the guys in this forum are very smart, and would be able to give me a for sure answer.
So to sum this up.
Can you use the main caps (or crank supports) from one b18a on another?
Is it neccesary to do an align bore on a block (that has just been resleeved) when assembling it?
Is my block really trash now?
Thanks alot for eveyones help.
Jamison
Jamison is offline   Reply With Quote
Old 01-19-2003, 06:08 PM   #2
JMinSi2000
Send a message via AIM to JMinSi2000
Default Re: align bore questions... (Jamison)
You need to do an align bore so you're pistons and bore will match. I'm not sure about using different main caps though. Who knows, you may get lucky. You could have a machine shop try to make some but I dont know.
JMinSi2000 is offline   Reply With Quote
Old 01-19-2003, 06:11 PM   #3
Jamison
Jamison's Avatar
Default Re: align bore questions... (JMinSi2000)
ok cool, thanks. any other people know more info?
Old 01-19-2003, 06:12 PM   #4
earl
earl's Avatar
Send a message via AIM to earl
Yes, after you align bore it
It could be necessary, depending if it was out of align
I wouldn't take your block, even if it was free
My question to you is why would you ever throw something like main caps away? Did you throw the main bearing bolts away also?
earl is offline   Reply With Quote
Old 01-19-2003, 06:20 PM   #5
Jamison
Jamison's Avatar
Default Re: align bore questions... (earl)
Honestly I didnt relize that they were that important, and you couldnt use some from another block. I threw everything away except the crank and block. Well it looks like the block is going in the trash now anyway. I guess I have just learned not to throw anything away. Thanks alot for the help.
Old 01-19-2003, 06:23 PM   #6
tony1
tony1's Avatar
Um, NO.... Click the image to open in full size.
tony1 is offline   Reply With Quote
Old 01-19-2003, 06:43 PM   #7
InfamousRS
InfamousRS's Avatar
Default Re: align bore questions... (tony1)
Can someone explain what an "align bore" is?
1994 Berlina Black DC4
<U>WANT TO BUY</U>
Precision .63 T3 ex. housings (for T31 wheel)
Tinker219 http://images.honda-tech.com/set1/smile/emthup.gif
Arturbo http://images.honda-tech.com/set1/smile/emthup.gif
Flamenco-T http://images.honda-tech.com/set1/smile/emthup.gif
Rocket http://images.honda-tech.com/set1/smile/emthup.gif
InfamousRS is offline   Reply With Quote
Old 01-19-2003, 06:45 PM   #8
SEFIxCivic
SEFIxCivic's Avatar
Send a message via AIM to SEFIxCivic
it makes kool furniture
SEFIxCivic is offline   Reply With Quote
Old 01-19-2003, 07:23 PM   #9
ninesecrx
ninesecrx's Avatar
Tony, that one made me giggle too...lol
http://www.laskeyracing.com 714.688.0222
engine building, parts sales, tech articles...stop by
Driveshaftshop.Cp.BDL.Portflow.ATI.Supertech.Paute r.Benson sleeves.ACL.Carrillo.etc
ninesecrx is offline   Reply With Quote
Old 01-19-2003, 08:45 PM   #10
Flamenco-T
Flamenco-T's Avatar
Send a message via AIM to Flamenco-T
well, is not...align bore doesn't serve the purpose of matching the bore size with the piston's diameter, regular boring can do that....all you need is the piston diameter size and skirt to wall clearance spec
one way to check bore for misalign to to insert a bar a shade smaller (very very tiny..) than the indicated bore size and see if the bar turn easily, it basically repair a problem of inconsistent bore along the cylinder walls....
stan
Shop Number (817) 439-3748
We carry :
Clutchmasters, NGK, Supertech, Quiafe, Goodridge, Precision Turbo, Walbro, Bosch, Tial Sport, Turbosmarts, AEM, Hondata, Cometic and more....
Flamenco-T is offline   Reply With Quote
Old 01-19-2003, 09:56 PM   #11
tony1
tony1's Avatar
Default Re: align bore questions... (Flamenco-T)
An align bore (i always thought it was called a "line bore", but i could be wrong) is boring the main bearing journals to make sure everything is straight. You can no longer use the honda color and bearing codes if this is done. I personally have not run into a block yet that has needed it after sleeving, but i'm not saying that none need it. Simple to check though. It's just a matter of checking the bearing clearances on the mains. This always has to be done if you are using the main caps from another motor. The bore is done with the main caps installed and you cannot mix them up.
[Modified by tony1, 12:57 AM 1/20/2003]
Old 01-19-2003, 10:01 PM   #12
Arturbo
Better than steak
Arturbo's Avatar
Send a message via AIM to Arturbo
maybe this will help: http://www.honda-tech.com/zerothread?id=218565
Just a has been...
Arturbo is offline   Reply With Quote
Old 01-19-2003, 10:10 PM   #13
uglyasscivic
uglyasscivic's Avatar
Default Re: align bore questions... (Arturbo)
I have had to do an Align bore? with every GE sleeve job. I think it is nothing but trouble on a honda because if the block was beat to **** and it is twisted or the saddles are beat you will run have to take out alot of aluminum to get it straight and it will move the crank up in the block, then pistons will probably stick out of the deck a couple thou. Click the image to open in full size. bad news from there Click the image to open in full size.
I know from my customers experience
9.36@159sfwd 9.00@167mph
Exedy-Full Race-Exospeed-Hondata-
Turbos Direct-Arias pistons
uglyasscivic is offline   Reply With Quote
Old 01-19-2003, 10:17 PM   #14
earl
earl's Avatar
Old school name is align bore but I actually saw a machine shop's price list that said line bore on it.
Old 01-29-2003, 11:02 AM   #15
VWkila
VWkila's Avatar
So, after the align bore, what bearings should I use?
tomatograndprix.com
the BLOG
VWkila is offline   Reply With Quote
Old 01-29-2003, 11:10 AM   #16
b18bturbo
b18bturbo's Avatar
Send a message via AIM to b18bturbo
Default Re: align bore questions... (VWkila)
You need spec your bearings to what clearance that you specifically run in your engine.
b18bturbo is offline   Reply With Quote
Old 01-29-2003, 11:11 AM   #17
sgT
sgT's Avatar
Send a message via ICQ to sgT Send a message via AIM to sgT
if you give the machinist your crank and a set of bearings, he can set the clearance
for you. So if you give him green bearings, then when he is done, you use
all green.
Stephen Sakai
1997 Integra R
http://www.sgt-racing.com
sgT is offline   Reply With Quote
Old 01-29-2003, 11:16 AM   #18
VTC_CiViC
2000 Pontiac Trans Am
My Garage
Send a message via AIM to VTC_CiViC
So then, and pardon the stupidity of my post but I want to make sure I completley understand this, a line bore has nothing to do with the cylinder bores correct? After all is the main bearing journals you are boring even. Tha being said, why/how does a sleeve job affect the main journals?
-Dave
-'08 Lancer Evolution X // '11 MDX // '00 TransAm WS6 // '95 Integra GS-R
VTC_CiViC is offline   Reply With Quote
Old 01-29-2003, 11:29 AM   #19
sporkcrx
sporkcrx's Avatar
Send a message via AIM to sporkcrx
Default Re: align bore questions... (VTC_boost-less_CiViC)
correct, it's just to make sure all the main caps are aligned.
360: iturnbolts
ShifterKart Mafia Member #006
the car the kart the bike
sporkcrx is offline   Reply With Quote
Old 01-29-2003, 11:30 AM   #20
sporkcrx
sporkcrx's Avatar
Default Re: align bore questions... (sporkcrx)
I think in his head he was just thinking about boring the cylinders, and just got them mixed up or something.
360: iturnbolts
Old 01-29-2003, 12:07 PM   #21
AVATAR
AVATAR's Avatar
I was aleways under the impression that "line boring" is what you do to the cylinder walls not the mains. "Align boring" is what is done to the mains- you make sure the main caps are "aligned"
If you aint drivin no benzes, you aint getting no friendzes.
AVATAR is offline   Reply With Quote
Old 01-29-2003, 12:16 PM   #22
BudaKai
Default Re: align bore questions... (AVATAR)
Well at least I'm not the only one that was confused on this topic. I went and asked a machinist last week about it.
Give us all your [B]BASE[/B]
*News Flash* BudaKai is the official Honda-tech.com Phsyco.
This has just been discovered by none other than the Honda-tech Phsycologist. ~SEFI8LOxCivic~
BudaKai is offline   Reply With Quote
Old 01-29-2003, 01:25 PM   #23
VWkila
VWkila's Avatar
Default Re: align bore questions... (tzsir)
"if you give the machinist your crank and a set of bearings, he can set the clearance
all green."
Ahh... So I should take my bearing in with my block when getting honing done?
[Modified by VWkila, 10:25 PM 1/29/2003]
tomatograndprix.com
the BLOG
Old 07-14-2011, 07:44 PM   #24
codyh1990
1995 Honda Civic
ok if you havnt figured it out yet
you SHOULD have your main caps align bored with your block, every block is different from every main, just like every bearing is different. if your selling the block i would put the sleeves on and not align the block. the sleeves have nothing to do with the aligning process. you may need your deck plained if the sleeves stick up tho.
aligning the crank insures the pistions are moving up and down straight and smooth if the alignment is too off your rods may snap and there goes all your work
as for bearings it depends on how they align the bore. they could make the bore larger by just drilling the hole bigger to straighten it in which case you will need larger bearings to fit the crank, or if they grind the top of the caps and bottoms of the rods then make the bore the oem size you can keep the oem bearing size but then your piston will sit lower. which can be fixed by a good decking job (shaving the deck)
if im wrong on anything here someone please let me know so im not handing out false info.
codyh1990 is offline   Reply With Quote
Old 07-14-2011, 08:12 PM   #25
guess_who
guess_who's Avatar
This thread is 8 years old.
guess_who is offline   Reply With Quote
align, b18, block, bore, bored, caps, dont, head, honda, integra, main, mixedupmaincapshondatech, portflow, sleeving, wrong
