What is an EVAP emission 2 way valve?
Old 01-16-2003, 08:40 PM
Jonathan_ED3's Avatar
Default What is an EVAP emission 2 way valve?
On Preludes, this sensor is hooked up to one of the nipples coming off from the EVAP cannister.
I need to know what exactly this is so I can figure out the vacuum wiring to put it into my civic.
Can anybody take a pic of it? It's nothing on the engine...it's the one nipple that doesn't go to the engine from the cannister.
I need to know if it's just a valve, or if it's an actual sensor that needs wiring to go with it.
If it's a valve....that'd be great! I can just hook it inline!
But if it's got wiring...I've got no clue what I'll do about it.
Anyway, any help will be greatly appreciated. TIA
Old 01-16-2003, 09:23 PM
Default Re: What is an EVAP emission 2 way valve? (hot_EG)
come on guys!
I don't have $60 to buy a manual
Old 01-16-2003, 10:01 PM
anyone?
Old 01-16-2003, 10:19 PM
743's Avatar
i cant help you but i just figured i'd let you know that you signature rocks nads. good luck.
Old 01-16-2003, 10:28 PM
Default Re: What is an EVAP emission 2 way valve? (-SevenFourThree-)
Thanks bro
for the bump
Old 01-17-2003, 01:16 PM
C'mon!
Somebody HAS to know this.
At least scan me some pics of the manual and let me figure it out!
I've got scans of most of the actual vacuum system...but it doesn't continue over to the EVAP Two Way Valve...
Old 01-17-2003, 01:52 PM
satan_srv's Avatar
Because the evaporated fuel goes both ways. the fumes that evaporated into your charcoal canister are sucked back into the tank for combustion when you drive the car.
There is a sensor that determines that the purge is taking place, or else you throw a code.
[Modified by satan_srv, 5:53 PM 1/17/2003]
jdm95
02-27-2012 07:57 AM
supercharged d
06-18-2009 12:45 PM
lowered94accord
05-07-2007 09:24 PM
sIcWiTiT
09-02-2006 03:09 PM
Confucius37
02-11-2005 08:48 AM
Quick Reply: What is an EVAP emission 2 way valve?
