Cam Gear weight: AEM vs. Skunk2
Old 10-06-2003, 03:11 PM
  #26
HotWheelz's Avatar
Default Re: (19924ws)
I had 3 to compare... the h22a skunk2 i had were extremly lighter than aem... also to fit the new style skunk2 you need to grind the plastic part of the cover.. (the half moon to clear, because the bolt is exactly the lenght needed to fit.. so when you clear the spacing you actually go through the plastic.. here is a pic to compare..
http://personal.nbnet.nb.ca/gbvautou/IMG_0878.JPG
look at the plastic cover...
this is my h22a built motor for my ek, mind you the headers different,so is the intake and other things
More PoWA!
ahhaah
Old 10-06-2003, 07:52 PM
  #27
OG triple OG
ATS*Mark's Avatar
Default Re: (HotWheelz)
my SRR cam gear i had to take the plastic piece behind the cam gear that the outer cover bolts to.....it rubed hella bad
Old 10-08-2003, 05:10 AM
  #28
KTeller8's Avatar
Skunk2 are far lighter then aem and stock:
Stock when i shipped a set out that were off my usdm h22 were a lot heavier then any..
i never had a chance to weight each one, but i know that the skunk2 are a lot cheaper to mail, and mail is done by weight
I have an extra skunk2 H22 gear here, just one thought , if anyone is looking for it:
Old 10-08-2003, 08:29 AM
  #29
kidaniel's Avatar
Default Re: (TURSpoonEK)
I plan on purchasing cam gears and type-s cams when I hit 60,000miles.
How much gain do you guys think I could gain with the mods I have now? 10-15hp with tuning?
Modified by kidaniel at 10:15 AM 10/8/2003
Old 10-08-2003, 08:41 AM
  #30
KTeller8's Avatar
Default Re: (kidaniel)
well you should see some decent gains from the cams.. but the gears are for fine tuning and should be set on a dyno: they dont add performance alone.. but do offer some weight reducing benifits
EJ8 GSR-T
04-14-2006 09:23 AM
xplanetearth420x
03-22-2006 10:17 PM
damonk
09-30-2004 09:20 AM
All-Motor H22A
12-29-2003 06:03 PM
Quick Reply: Cam Gear weight: AEM vs. Skunk2
