Differences between D16Z6 and D16Y8?
Old 03-05-2009, 03:04 PM
  #26
EK9r!der's Avatar
Default Re: Differences between D16Z6 and D16Y8?
i say z6...
Old 04-16-2009, 07:47 AM
  #27
lileghatch's Avatar
i say the z6 with a y8 head....thats a good combo
Old 04-16-2009, 08:19 AM
  #28
newtron63h's Avatar
im a big fan of the Z6, but honestly they are almost identical engines. the Y8 is a little more complicated because its OBDII and the extra sensors that com with that, BUT that makes it more tuneable and you can get mroe information from the engine with OBDII.
my mom has a 93 Si and the Z6 in there is absolutely bulletproof. still low mileage(a lil over 150K) bought it brand new and there hasnt been a single mechanical issue with the engine. changed the valve cover gasket over xmas, valve lash was check at 90K with no adjustment needed, checked again when i was doing the gasket and no adjustment was needed.
i dont see much difference in potential output in the 2 engines. same displacement, VERY similar specs otherwise. and once you start talking about tuning and modding, those differences become more and more insignificant.
Old 06-09-2009, 10:38 AM
  #29
TRIAL USER
B16Turbo-BRA's Avatar
will forged pistons (in my case CP) part # SC7126 (77.5 with 11 CR) made for a D16Z6:
fit a D16Y8 with a skunk 2 stage 1 cam?
Old 07-07-2010, 05:54 AM
  #30
92civicsi's Avatar
I Bought a Used D16y8 To put in my 93 SI that came with a D16z6 from factory, what is needed to get it running? Z6 Distributor wont bolt up, but i cant get it to run with the distributor that came with the y8. I was told i could just drop in the engine and I would be good.
Thanks
Old 07-07-2010, 06:13 AM
  #31
mayfly's Avatar
convert to OBD2 with a jumper harness and use a p2p ecu i believe is the y8 one.
Old 07-07-2010, 06:48 AM
  #32
apexi_rsx's Avatar
z6 has 2 oiling ports on the crank for the rods as the y8 has just one that's why the y8 is more prone to spinning rod bearings. it is a myth about the y8 oil pump not being sufficient with oil. the z6 oil pump has bigger gears in the oil pump so it probably does flow a lil more but ive been running a stock y8 oil pump on my z6 for 2 yrs with no oil pressure problems. the y8 tranny is better because it has steel shift forks as the z6 has aluminum.... get the facts str8....
Old 07-07-2010, 06:57 AM
  #33
apexi_rsx's Avatar
Thanks
only the top distributor bolt lines up. this is sufficient enough and is how ive been running my y8 dizzy on my z6 for 2 yrs. it works. u may have to ream out the slot a little bit but it works...
Old 07-07-2010, 07:08 AM
  #34
lovelove's Avatar
Y8 is weak.....raced one with my Z6 and pulled it on the highway; not once, not twice, but 3 times already.
Old 07-07-2010, 07:32 AM
  #35
apexi_rsx's Avatar
any D series is weak sauce without boost
Old 07-08-2010, 05:26 AM
  #36
lovelove's Avatar
Amen Brother!!!!
Old 07-06-2011, 02:17 PM
  #37
t12tninja's Avatar
Default Re: Differences between D16Z6 and D16Y8? (Spade)
Originally Posted by Leb_CRX
can I put a z6 head on a y7 block (OBD-2) if I use a y8 distributor? or is there somethign else that wont match up cause of ODB1/2
I know I should make my own post, I did and I have and no answer...maybe y'all can help me
|eb_CRX
damn i know im late and all but i have that engine z6 head with a y7 bottom havent put it in yet but i took it out of a EG so i think it works and i have the same question about the dizzy
Old 07-06-2011, 03:46 PM
  #38
D16SiHatch's Avatar
the y8 dizzy on a z6 head can work, but it's not pretty.
http://i43.tinypic.com/2mx4d29.jpg
better off using the z6 dizzy and wiring in an obd2 plug. It's what i did when dropping a z6 in my ek. here's a chart type deal i put together. it really is that simple lol.
Old 02-21-2012, 06:49 AM
  #39
fox_the_shadow's Avatar
what would be the best way to combine the two or is it impossible due to obd1 obd2? like z6 block y8 head y8 intake mani y8 tranny?
Old 02-21-2012, 07:01 AM
  #40
Icon2 Re: Differences between D16Z6 and D16Y8?
i currently have a z6 in my car and might be getting a y8 and i was thinking of putting them together in the best possible way first i would like to know if its even possible or would it just be better to keep the z6 together and build the y8?
Old 02-21-2012, 07:12 AM
  #41
The Grumpiest
grumblemarc's Avatar
Don't Frankenstein anything.
Old 02-21-2012, 07:15 AM
  #42
sde780's Avatar
Keep the y8 together and build the Z6
Old 02-21-2012, 11:47 AM
  #43
jbpnoman's Avatar
And stop bumping 10 year old threads. Just start a new one.
Old 02-21-2012, 03:36 PM
  #44
88EFrex's Avatar
do NOT forget that the Z6 is lacking in the crank position sensor that are found on OBD2 D series engines. on the OBD1 engines the crank position is in the distributor i believe. im currently encountering this problem because i have an OBD1 engine in an OBD2 vehicle and i want it to be able to pass PA state emissions LEGALLY haha good luck
Old 02-24-2012, 11:50 AM
  #45
k thx
Old 04-25-2012, 11:35 AM
  #46
Hussaini's Avatar
I've just put a Z6 in a car that came with a Y8, I'm using the original ECU (P2P) I guess, using the OBD-2 distributor I wasn't able to get spark, please help ........ and what do I do with the CKP sensor
Old 05-15-2012, 05:24 AM
  #47
99exxguy123's Avatar
I got a quick ? I have a d16y8 with a blown bottom end can I buy a d16z6 block bolt and go or will I need to change some stuff and if so can u please tell me what I need to do this...its my daily driver and I need it back asap please and thank u
Old 08-27-2012, 07:14 AM
  #48
shawn_thorning2's Avatar
Can anyone tell me if i can take the D16Z6 out swap heads and use a D16Y8 block in place because my d16z6 has a rod hanging out
Old 03-18-2013, 11:23 AM
  #49
RyBread68's Avatar
I know its an old thread but I figure if I came across it....somebody else will. I recently (in December) completed my first swap ever, with no real direction. I have a 92 civic hatch cx. It came with a d15b7, 5-speed. I was told it was a "just drop it in" kinda job. Not the truth by any means. So long story short....I went from beginner/intermediate mechanic to an intermediate/advanced mechanic from all the research and conversions ive done.
I originally used the block and head from a Y8 and everything else was from the d15. Of course it lacked power but started up with no issues or CEL's. The only thing I had to do was NOT connect the crank sensor.
I did however have to wire the vtec, convert from a one wire to a 4 wire O2 sensor, relocate the iac sensor, convert a plug for a sensor on the fuel rail, but that all came as soon as I put the Y8 intake manifold on. I have since installed headers, and have the Y8 trans which is being cleaned before its install.
By now you should be wondering what the point of all of this is...
Point: I am still using the d15 distributor and have zero issues. Besides what I said I swapped, you can use for the obd1 wiring and no need to convert all that other crap...its just a waste of time.
Hope this cleared up a few things...
Old 10-14-2019, 05:00 PM
  #50
Elijah Larivee's Avatar
I was needing to know is the internals of a D16Y8 same as the D16Z6 I have the Z6 motor an bottom end is starting to knock just wanted to know everything I keep searching comes up to the Y8 instead of Z6
AEFM88
14
10-22-2011 01:12 PM
TheDrizzle50
21
09-21-2007 04:23 AM
ATS*VEEE
20
11-03-2002 09:57 PM
130hp
11
08-09-2002 03:32 AM
MIDNIGHT
01-29-2002 01:41 PM
Quick Reply: Differences between D16Z6 and D16Y8?
