| Welcome to Honda-Tech! | ||
#1 |
Like the title says, can someone run down the major differences between these two motors?
JRSC'd Milano Red 1995 Civic Si Hunchback Someday I'll break open the piggybank and get an S2000! |
#2 |
2003 Ford Expedition |
OBDI and OBDII
Headgasket. Intake manifold. Chamber design. Cam.
Bring on the ditch pickles!!! |
#3 | |
hey spade, anyway we could drill down even more.. like:
Real Men http://images.honda-tech.com/set1/smile/emlove.gif Jesus |
#4 |
Yup.
Y8 has thinnest D series head gasket. OBDII..different distributor Second O2 sensor, Knock sensor, all the pain in the *** crap you don't want to deal with when attempting to tune an engine. Y8 larger runners that are slightly shorter. Chamber: smaller and more angular for better burn. Cam: Slightly longer duration. 1-2 degrees.
#5 |
The Z6 has the better bottom end while the Y8 has the better up top. Honda made that Z6 block stronger and the Z6 has the wonderful and tunable P28 ECU. The Y8 has the better tranny. The gears are closer on the Y8. That's all that I can think of right now. I'm sure there's a lot more, and I'm sure the gurus of H-T know them.
[B][I]2004 Bright Silver Metallic Dodge SRT-4[/I][/B] |
#6 |
so is there an advantage to swapping in a y8 tranny over my stock Z6?...thanks...
-- Rest In Peace Jordan Miller - http://www.jordanblakemiller.com Looking for a free ipod? camera? etc? Check out Referral Swapper. Trade referrals with people who have what you need, and what they want! |
#7 | |
#8 |
I agree. The tranny is better, but not that much better. I don't have the tranny because I swapped trannies. I have it because it came with the engine and car. The SRR would probably be a better choice.
#9 |
1994 Acura Integra |
How exactly did they make the Z6 block stronger ?
The Past: 97 DB8- Built LSVT@12Psi - The MAGIC SHOW * R.I.P. 09-16-02* The Present 1993 DX GSR Hatch - The Clone I'd rather be turbo |
#10 | |
| Garage is empty, add now |
As far as up top, I think the z6 doesn't fare so well in terms of quench zones and it handles combustion gases less efficently than the Y8.
"I feel home when I'm chillin outside with the people I know" ...OAR |
#11 |
Well said!
#12 |
you guys amaze me
#13 |
Don't forget you could just get LS rods if you are worried about your Y8 having weak rods.
#14 |
Of course you could, but that would be modifying it. The question was what is the difference between the z6 and y8. It sounds like stock z6 vs stock y8. We all could come up with ways that the two could be improved but that isn't the discussion.
[Modified by SILINITY16, 4:37 PM 11/19/2002]
#15 |
Good stuff. Thanks guys.
#16 |
Spade, the Y8 trans is the beter trans, and if you are going to auto-x I would reccomend the Y8 trans over the Z6 Trans anyday, teh Z6 Trans has Aluminum shifter forks, and the Y8 is steel, the Z6 has the tendoncy to bend when used hard, even break....
Jesse |
#17 |
All i could see is both engines are terrible in producing large amounts of horsepower
. I know this because i have the d16z6.
#18 | |
Location: Why so you can pretend like youre interested, FL/OK
The SRR final drive kit, more preferred over the Vti LSD equipped transmission or just a greater addition on to the Vti transmission?
"All you have to do is fight for what you want. You fight for what you want you can get it." |
#19 |
seems like you guys got every difference.
functionality |
#20 | |
#21 |
2000 Pontiac Trans AmMy Garage |
As I'm sure Mr. Bone will state, the S40 (I think thats the 5G EX) and K4F trannies use the same ratio's, but the 6G trannys are physically stronger internally.
-Dave -'08 Lancer Evolution X // '11 MDX // '00 TransAm WS6 // '95 Integra GS-R |
#22 | |
#23 | |
#24 |
can I put a z6 head on a y7 block (OBD-2) if I use a y8 distributor? or is there somethign else that wont match up cause of ODB1/2
I know I should make my own post, I did and I have and no answer...maybe y'all can help me |eb_CRX |
#25 |
ok so can i get opinions which is better? the y8 or z6?
| Tags |
| block, d16y8, d16z6, difference, distributor, k4f, knock, make, sensor, stronger, tranny, trans, vs, y8, z6 |
