> Acura Integra Type-R
Old 11-08-2002, 01:10 PM   #1
jdmspoonitr
jdmspoonitr's Avatar
iTrader Rating: (1)
Default how often should I change spark plugs?
right now i have 15,000 miles. has been tracked a couple times at most. I probably need to change them, but is there anything else I need to change along with the plugs??? And secondly I think I saw a past post that recommended the stock plugs over aftermarket. Just checking. thanks for all the help guys.
01 ITR 178whp DSR DynoJet
06 Evo MR - 438/377 on E85 (GST Mustang Dyno)
My YouTube Channel http://www.youtube.com/user/jdmspoonitr
jdmspoonitr is offline   Reply With Quote
Old 11-08-2002, 02:12 PM   #2
Tweakmeister
Tweakmeister's Avatar
Send a message via AIM to Tweakmeister
Default Re: how often should I change spark plugs? (jdmspoonitr)
I changed mine around 30k and noticed a big difference. At the very least make sure yours are gapped correctly.
I replaced mine with BERU Silverstone S3F
Hogen's [Import Parts] (closed)
'99 SSBP GS-R SOLD // '08 Infiniti FX35
Colossians 2:8
Tweakmeister is offline   Reply With Quote
Old 11-08-2002, 02:26 PM   #3
IntegraGSR23
Default Re: how often should I change spark plugs? (Tweakmeister)
Where did you pick those up at? and how much??
CL9 Squad #57
IntegraGSR23 is offline   Reply With Quote
Old 11-08-2002, 02:32 PM   #4
Nameless RB26
Nameless RB26's Avatar
Default Re: how often should I change spark plugs? (IntegraGSR23)
I clean my spark plugs with a high grit sandpaper, and wipe them off good with some gas.
That's only when I'm bored though. I think stock plugs should be replaced @60k miles. Platinums are about 20k I believe..
89' 240sx
Nameless RB26 is offline   Reply With Quote
Old 11-08-2002, 03:02 PM   #5
Bbasso
Bbasso's Avatar
Default Re: how often should I change spark plugs? (Nameless)
if your putting sand paper to the spark plug you might be sanding off the platnim finish... and also making the gap bigger...
Just use chemicals or buy new- for .99 I buy Champion RC12MC4 they last 7-10k miles and work good.
[Modified by Bbasso, 7:03 PM 11/8/2002]
Bbasso is offline   Reply With Quote
Old 11-08-2002, 03:31 PM   #6
Tweakmeister
I bought my Silverstones from Nology...but I've since found cheaper (I just forget where )
I would recommend shopping around a bit.
http://www.hogens.com/car/default.ph...lugs/index.php
Colossians 2:8
Old 11-08-2002, 05:48 PM   #7
Dirt
Dirt's Avatar
everyday just like w33d
Dirt is offline   Reply With Quote
Old 11-08-2002, 07:39 PM   #8
SUPERAUTOBACS
SUPERAUTOBACS's Avatar
Default Re: how often should I change spark plugs? (BrewCityR)
Does anyone know the benefits of using copper plugs? Any?
I remember reading a loong time ago that copper plugs perform better (in what way, i cant remember) but dont last nearly as long as platinum tipped plugs.
SUPERAUTOBACS is offline   Reply With Quote
Old 11-08-2002, 11:14 PM   #9
vtec.dc2
vtec.dc2's Avatar
stock plugs is all i use.. - with stock ecu its easy to run healthy to 40K miles, but good idea to have them checked at least every 30K... with aftermarket ecu/ignition/changed timing - its a good idea to cut it down to 10-15K..
also check dist. rotor - make sure its not fried or anything.. -
maybe distribur cap - should be fine at 15K
vtec.dc2 is offline   Reply With Quote
Old 11-09-2002, 06:26 PM   #10
Teepo
Teepo's Avatar
Default Re: how often should I change spark plugs? (vtec.dc2)
NGK #2380 ......7 platinums baby
[B]FORMERLY KNOWN AS ITR1150 [/B]
[B]Best ET: [/B] 13.9 @ 99.6 MPH H/E/Untuned V-AFC....ball Re010's [img]http://images.honda-tech.com/set1/smile/emsmileo.gif[/img]
[B]F/S or Trade[/B] [url="http://honda-tech.com/zerothread?id=760071"]http://honda-tech.com/zerothread?id=760071[/url]
[B]References[/B]
Efzero-Sqwerz-Orgy-Sinbro1-Titan Motorsports.com-Vietshinobi
Charlie Moua-Tooky2-GsrSdn-OutLawDc2-Determined-Dc2Lun
Teepo is offline   Reply With Quote
2002, 2005, accord, change, civic, dirt, fit, honda, hybrid, odyseey, plug, plugs, replace, ruckus, spark
