tools for changing flywheel/clutch ( ring gear holder, or crank pulley wrench?)
Old 11-06-2002, 12:34 PM
Dan GSR's Avatar
Default tools for changing flywheel/clutch ( ring gear holder, or crank pulley wrench?)
Can I use the moroso crank pully wrench to hold the flywheel from spinning when I torque down the bolts? Any possibility that it can mess up the timing?
I know I can just buy the Ring Gear Holder from Acura, its about the same price as the crank pulley wrench...but if i buy the crank pulley wrench I can use it for other things
Right tools for the job....thats my thinking
So can I just use the crank pulley wrench??
Old 11-06-2002, 12:41 PM
Jesse H's Avatar
Default Re: tools for changing flywheel/clutch (Dan GSR)
That tool is perfect for the job. I have the honda part, and it looks pretty much the same. Your timing won't be messed with since the timing belt isn't removed and fiddled with.
Definately get this over other tool, so u can also use it to replace the timing belt. BTW, loosen the axle nuts when the wheels are still on the ground. Weight of the car makes it easier.
Old 11-06-2002, 04:24 PM
Dan GSR's Avatar
Default Re: tools for changing flywheel/clutch (Jesse H)
bttt
Old 11-06-2002, 05:18 PM
baonest1's Avatar
hey good info guys.... BTW dan, how much did the wrench cost. im finishing up my motor soon and gonna probably get one if not that expensive, or maybe see if anyone would let me borrow it.
thanx man
Old 11-06-2002, 05:24 PM
Dan GSR's Avatar
Default Re: tools for changing flywheel/clutch (baonest)
uh I'm the one asking a question
I don't have either of the tools...im asking which to get
you can get the crank pulley tool from http://www.summitracing.com
Old 11-06-2002, 06:16 PM
tSuperbike69's Avatar
You can get a smaller one that you hook up to a breaker bar and it is like $50-$60 from Matco tools. It is smaller and easier to store. That is what is in my toolbox right now
Old 11-06-2002, 06:58 PM
Dan GSR's Avatar
Default Re: tools for changing flywheel/clutch (tSuperbike69)
o well i just ordered the ring gear holder from acuraautomotivparts.com
Right tool for the job....if the Helms says use it...then i will
clemsoncb7
12-06-2006 04:53 PM
Dan GSR
04-04-2005 04:29 AM
DaX
13
12-04-2004 11:21 PM
crxcess
02-19-2004 08:24 PM
NAZC
11
01-15-2003 04:52 AM
Quick Reply: tools for changing flywheel/clutch ( ring gear holder, or crank pulley wrench?)
