In line walbro giving me problems
Old 09-01-2014, 12:54 PM
Lsv4free's Avatar
Default In line walbro giving me problems
Alright so it's a 95 4dr eg. LsV with a cell in the trunk.
-pump is right off the cell
-pump is pre filtered before fuel runs threw it
- pump is relayed with a 12v 30amp relay
-brand new ground wire
-fuel power supply is completely separate from the car
When I start the car it runs fine for about 10 minutes and then the pump gets hot and the pump starts acting up and winning more then normal
-I'm on my third pump thinking it was the pump going bad the first time then walbro directly requested I try a smaller one
-I've tried (2) 255 pumps & now I'm on to a 155 (recommended by walbro per my setup)
I noticed today while messing with it the only thing that helped was when I rub an ice pack on it while she runs to counter act the heating up of the pump
Any ideas would be greatly appreciated
Old 09-01-2014, 06:13 PM
Hysterically Calm
TomCat39's Avatar
Default Re: In line walbro giving me problems
Filters cause a lot of flow resistance. I would think the filter before the pump is making the pump work harder that it should to draw in fluid. I think the pump's strength is in pushing the flow out and can handle the pressure buildup after the pump than before.
I really don't see a whole lot of damage being possible to the pump from debris to require a filter before the pump. The filter I always thought was to protect the injectors and cylinders from debris.
I could be way off base but that's the first thing that comes to mind about your pumps burning up and having a full fuel filter in place before the pump.
ahobbs
02-23-2011 11:08 AM
heyitzspikey
03-04-2007 02:46 PM
Green Lude 93
07-25-2004 11:35 PM
recall
05-05-2002 04:11 PM
Quick Reply: In line walbro giving me problems
