innovative mounts which rubber??
Old 09-01-2014, 11:30 AM
EJtypeR's Avatar
Default innovative mounts which rubber??
I've decided to go with innovative steel mounts just not sure on the rubber. It's my DD so I definitely don't want solid mounts. I had the old place racing mounts in a car I had a long time ago and I didn't think they were that bad as far as vibration goes. I came across a old thread where the billet mount had the softest rubber in them and they came apart. So is this still a issue or would I be fine with the red or should I go with the black?
Old 09-01-2014, 11:37 AM
B_Swapped93's Avatar
Default Re: innovative mounts which rubber??
Under 70A duro-meter rating...even 70A got annoying with my integra when I had it. 62A I believe is the universal "street" rating for innovative hasport etc.
Old 09-01-2014, 12:03 PM
Hysterically Calm
TomCat39's Avatar
^^--- what he said is good advise if you want comfort.
Of note, color doesn't matter, it's all about the duro-meter rating of the rubber regardless of color.
Old 09-01-2014, 12:20 PM
EJtypeR's Avatar
Did you have the billet or steel mounts?
Old 09-01-2014, 12:33 PM
I was dumb and got the hasport billet ones with a 72A duro-meter rating, it made the car notably vibrate even the rear view mirror was blurry,
mind you they are very beautiful, especially when polished that's why I got them(purple coloured from hasport)
Old 09-01-2014, 12:50 PM
I never narc'd on nobody!
NotARaCist's Avatar
62/65 for street use. 72/75 for mixed use. 82/85 for track use. It's that simple.
Old 09-01-2014, 07:05 PM
EJtypeR's Avatar
I can get a really good deal on a set of steel innovative mounts with the 75 inserts. What's everyone running for the lower 2 mounts that bolt under the car?
Old 09-01-2014, 07:25 PM
NotARaCist's Avatar
With 72/75, you don't really need them, but if you want them, OEM is fine.
Old 09-01-2014, 08:47 PM
underrated's Avatar
I'm using oem with energy inserts. Hardrace also has them, was gonna try those next. For the other 3 I'm using innovate billet mounts with 75a bushings. Vibrations are fine, it mostly vibrates at idle. I have friends that rode with me and didn't say nothing at all.
90civicstdgold
10-28-2010 01:58 AM
pubestripe
10-03-2005 09:29 PM
fasthatchb18c1
05-08-2005 01:11 PM
JsEFx
39
11-01-2004 10:28 AM
Quick Reply: innovative mounts which rubber??
