Any way to test a crank position sensor??
Old 08-31-2014, 04:01 PM
Rickmanalex's Avatar
Default Any way to test a crank position sensor??
01 accord 2.3 died while driving... New dizzy... new ignition switch... Power to the dizzy.... No spark... getting Fuel... Think it's the crank sensor.... all help is appreciated
Old 08-31-2014, 07:45 PM
GhostAccord's Avatar
Default Re: Any way to test a crank position sensor??
Have you tested the ignitor?
I'm pretty sure the only sensor in the '01 distributor is the cylinder position sensor. The TDC and CKP are both located down behind the crank pulley/timing cover. There are also tests for those as well.
Do you have access to a multimeter to check resistance of the sensors?
T-Mo
05-11-2012 05:56 PM
2000siturboR
11-06-2009 03:29 PM
Beau Gotti
11
05-07-2006 11:04 AM
who00knows
01-14-2003 10:32 AM
prjctCIVIC
08-26-2002 08:34 PM
Quick Reply: Any way to test a crank position sensor??
