Old 10-31-2002, 06:56 PM   #1
96ek
96ek's Avatar
Default How do you remove fuel injectors??
i was wondering if anyonw had a diagram or description of how to remove fuel injectors and or fuel rail with injectors?? ( I did a search and came up with nothing.
Any help is greatly appreciated
Thanks in advance
96ek is offline   Reply With Quote
Old 10-31-2002, 07:26 PM   #2
B19CivicHB
B19CivicHB's Avatar
Send a message via AIM to B19CivicHB
Default Re: How do you remove fuel injectors?? (96ek)
Easy.
Unbolt the fuel rail, and bingo, injectors are out. It is literally that easy. Go look at the intake manifold and fuel rail and you'll see how easy it really is.
I believe there are 3 nuts that hold the fuel rail to the intake manifold.
hope that helped a bit,
-Nick-
B19CivicHB is offline   Reply With Quote
Old 10-31-2002, 07:27 PM   #3
splitime
splitime's Avatar
Send a message via AIM to splitime
Default Re: How do you remove fuel injectors?? (B19CivicHB)
release the fuel pressure first, i do the fuel cap and also loosen the nut on the fuel filter....
"Or maybe it was just bling and he had a little tiny dick and needed a way to impress the bitches." - CRX Lee
"Street Racing is like kissing your sister.... it just doesn't make any sense."
splitime is offline   Reply With Quote
Old 10-31-2002, 08:06 PM   #4
Evil_Wizard
Evil_Wizard's Avatar
Send a message via AIM to Evil_Wizard
Default Re: How do you remove fuel injectors?? (splitime)
2 minute job. Like he said just release the pressure first.
Oil leak?What oil leak? That's just sweat from all that horsepower!
Evil_Wizard is offline   Reply With Quote
Old 10-31-2002, 08:35 PM   #5
96ek
96ek's Avatar
Default Re: How do you remove fuel injectors?? (Extreme_Hybrid_Hatch)
Do you know where I can find a how-to on this?? If not do you know what size sockets i need and is an extension required?? How do the injectors themselvs come out? any trick to it??
I really appreciate your help on this one. ( Iam going to attempt a fuel injector swap with my friend to see if they are the problem)
Thanks in Advance
Old 10-31-2002, 08:58 PM   #6
96ek
96ek's Avatar
up^up^
Old 10-31-2002, 09:09 PM   #7
DeepSi
DeepSi's Avatar
this is how to change the fuel rail but one more step is to yank the fuel injectors out of the IM.
http://www.c-speedracing.com/howto/f.../fuelrail.html
it is pretty easy just take your time, have a shop towel to catch the little excess gas, and be patient
hope this helps
-deepsi
2000 Civic Si -- Powered by Greddy
187 hp, 136 tq @ 5psi
Proud Member of <FONT COLOR="blue">Greddy Mafia</FONT>
Never argue with an idiot, they only drag you down to their level and beat you with experience.
DeepSi is offline   Reply With Quote
Old 10-31-2002, 09:13 PM   #8
2000si
Default Re: How do you remove fuel injectors?? (DeepSi)
i heard that there is a a little screen in front of each injector and if you take that off, you get a little boost in power. has anyone done this, and if so will this effect your motor in any day. any possible problems related to this maybe. oh ya, i have a 00 si
thanks
2000si is offline   Reply With Quote
Old 10-31-2002, 09:14 PM   #9
DeepSi
DeepSi's Avatar
Default Re: How do you remove fuel injectors?? (2000si)
I have not seen these screens that you are talking about. i replaced my fuel injectors and i looked at my fuel injectors and there was no screen infornt of them. I also have a 2000 civic si.
-deepsi
Old 11-01-2002, 08:06 PM   #10
96ek
96ek's Avatar
Thanks Alot Deep Si, I really appreciate your help.
So if i understand correctly once you have disconected the fuel rail you just yank the injectors out?? will they get damaged?? any trick??
Sorry about all the questions guys but i really don't want to f*** up anything.
Thanks again
Old 11-02-2002, 07:39 AM   #11
96ek
96ek's Avatar
Sorry for the newb questions but I really need the help.
Old 11-03-2002, 08:42 AM   #12
96ek
96ek's Avatar
Anyone???
Old 05-23-2013, 12:37 PM   #13
d16y7ohwell
thanks
-deepsi
this is on the pressurized side of the fuel injector and i would find it hard to believe removing the screen would have any effect on performance. i would keep them there. theyre there for a reason... to keep crap outta the fuel injector
sorry for the 11 year bump but i figured it was necessary since nobody addressed this
d16y7ohwell is offline   Reply With Quote
Old 09-02-2013, 10:35 PM   #14
Chris Dodd
Dopey222
hello,
thank you for updating the post. i myself was wondering what these "plug/screen" things were. would removing them cause it to run rich? i ordered my injectors off of ebay and 3 of them had the screen and the other did not so i installed them withou the screen. i have 1991 civic si.
Chris Dodd is offline   Reply With Quote
96, accord, civic, clean, fue, fuel, honda, hondatech, how, injector, injectors, rail, remove, removing, screens
Similar Threads
Fuel Injector Problem Phoodles Tech/Misc 10 09-21-2013 11:05 AM
1989 Dual point fuel injection (DPFI) fault DCcrx Honda CRX / EF Civic (1988-1991) 4 06-04-2013 08:23 AM
94 civic ex fuel injector removal 14psi Honda Civic/Del Sol (1992 - 2000) 14 05-03-2013 07:05 PM
fuel injector problem Gideon Sol Honda Civic/Del Sol (1992 - 2000) 2 03-30-2013 06:31 AM
Too much fuel in cylinder? HondaGSX Hybrid/Engine swaps 2 09-01-2012 06:28 PM
