03 Accord P0301 misfire
Old 08-24-2014, 09:46 AM
eyez's Avatar
Icon6 03 Accord P0301 misfire
I have a 03 accord 4cyl.
I have recently had the check engine light come on, giving me a code for misfire in cylinder 1.
Hoping for a realitively easy fix, I went ahead & got 4 new plugs and changed them.
Well, when the engine is cold, it starts & runs fine. After it warms up, I get the code back, while idle at stop lights/signs. While driving, everything seems okay. I switched all the coils around, figuring that if that was the bad culpurit, it would change, but after clearing the codes, and retesting, I am still getting the code for misfire in Cylinder 1.
I've been trying to check the site here, but not seeming to have much luck. Anyone have any suggestions / idea's, besides taking it to a mechanic?
Thanks!!!
Old 08-24-2014, 09:56 AM
timmbo's Avatar
Default Re: 03 Accord P0301 misfire
How many miles on it?
Old 08-26-2014, 05:37 PM
eyez's Avatar
sorry for the delay, it has 151,000 miles
Old 08-26-2014, 06:04 PM
rockycat's Avatar
Change the #1 coil to another cylinder and see if the code changes to that cylinder.
Old 08-27-2014, 03:31 PM
eyez's Avatar
I changed all the coils, and still came up with the #1 misfire.
Old 08-27-2014, 06:20 PM
lazlong's Avatar
Next step is to swap injectors and see if the mis-fire follows the injector. If it's not the injector then you need to do a compression test, then a leakdown test if there is loss of compression.
Old 08-29-2014, 06:50 AM
eyez's Avatar
Well, I went to test / swap the injectors, and somehow the wire wasn't plugged in all the way on injector 1.
Not sure how it got that way, but drove it around for 45 minutes, and no misfires, or CEL coming on, so hopefully, that is all it was ... another learning experience.
Thanks for the help!!!
glenlakesbob@gm
11-15-2017 07:43 AM
bigfrank1130
01-21-2015 03:52 AM
Derek Pierson
05-25-2013 12:45 AM
SuppaClean96Ex
02-01-2009 08:51 PM
VTC_CiViC
02-25-2005 11:34 AM
Quick Reply: 03 Accord P0301 misfire
