Tire and wheel noob needs help
Old 08-21-2014, 11:29 PM
pxlds's Avatar
Default Tire and wheel noob needs help
I got a em1 and i have no clue anything about tires and wheels i have an idea of what kind of wheels i want but i wanna lower my car and need size suggestions i guess i want it to be low and camber the rear somewhat if neccesary but any type of knowledge of tire sizes would be helpful the wheels im thinking about are rota grids are they a good sponsor of wheels ?? I dont wanna go around with some busted rims at the end of the day
Old 08-25-2014, 09:24 PM
j_wod2000's Avatar
Default Re: Tire and wheel noob needs help
There's quite a range if sizes you could run. It depends on what you really want to do with the car. 15-17's will fit comfortably in those wells depending on offset and width. Tire size will depend on which wheel size you get. Some common sizes are 15x7 with a 205/50 tire, 16x7 with a 205/45 tire, 17x7 with a 205/40 tire. Just examples. As far as offset go's which is how deep or shallow the hub of the wheel sits in the barrel of the wheels, will also determine on tire size for proper fitment. For example, an average offset for a honda is around +50, which puts the wheel further under the vehicle. The lower the number in offset, let's say +36 will push the wheel further out from under the vehicle. All of these measurements as far as offset and tire size are in metric (mm's).
Moody Inc.
06-22-2018 11:12 AM
EM1SIGuy
06-01-2011 06:35 AM
ProricanEF
02-01-2011 09:58 AM
1LowSOHC
10-18-2009 01:23 PM
YipMan_Style
02-12-2008 03:43 PM
Quick Reply: Tire and wheel noob needs help
