Adjusting valves 2001 CR-V
Old 08-21-2014, 09:19 AM
Atauto's Avatar
Default Adjusting valves 2001 CR-V
I'm wanting to adjust the valves on 2001 CR-V and it would be great if anybody has any advice/information on the best way to complete this task Also I'm worried that I'm to late in adjusting them because the rpm drops rapidly when I start up the car but then goes back up to idle rpm in 10ish seconds, is this an indication that my valves are burnt and how would I conform this?
Old 08-21-2014, 11:11 AM
Skillachie's Avatar
Default Re: Adjusting valves 2001 CR-V
http://lmgtfy.com/?q=Adjusting+valves+2001+CR-V
The first one that pops up is the one i use
(How to adjust your valves, 97-01 CRV)
Old 10-29-2014, 06:35 AM
Sooner1's Avatar
I adjusted mine and it did the trick....should be adjusted about every 30K miles. Unfortunately Honda said valve adjust at 100k which was too late. .005 fuel /.008 exhaust. +/- .001
CarGuy91
14
09-16-2013 05:32 AM
str8JDMteggy
11-10-2006 02:03 PM
austrian type-R
09-30-2002 03:08 PM
Crossett
11-15-2001 02:19 PM
evo
08-24-2001 12:56 PM
Quick Reply: Adjusting valves 2001 CR-V
