Slow acceleration off first gear
Old 08-19-2014, 07:09 PM
xW01FxGANGx's Avatar
Default Slow acceleration off first gear
So my car just got a engine with about 98k in it. before when it had the other engine i use to step all the way down on the accelerator and it would make the tires chirp a little and then accelerate fast. now it doesn't do that. When i press my foot all the way down the engine sounds as if im in a gear to high for the speed i am going at. it does this for a couple seconds and then it accelerates. what could this be?
Old 08-19-2014, 07:17 PM
yippee-ki-yay
eHMxhACk's Avatar
Default Re: Slow acceleration off first gear
A riddle?
Maybe your car had a B18C5 in it before and now it has a D15B7. Could that be it?
eH.
Old 08-19-2014, 07:20 PM
Retired Moderator
EsotericImage's Avatar
Not sure if serious
Old 08-19-2014, 07:42 PM
I never narc'd on nobody!
NotARaCist's Avatar
Hey OP.
Yeah, OP, I'm looking at you.
You've been here since 2013.
There is absolutely zero excuse for what you just did.
Old 08-19-2014, 08:04 PM
Humphrizzle's Avatar
Auto or manual?
Old 08-19-2014, 08:12 PM
longest project ever
lostforawhile's Avatar
if it's an auto it's just out of adjustment
Old 08-19-2014, 08:14 PM
TV cable is out of adjustment sorry
Old 08-19-2014, 08:22 PM
Or linear solenoid
Old 08-19-2014, 08:25 PM
wasnt sure what year, since the engine was pulled and a lot of stuff disturbed, it's probably a matter of getting everything adjusted again is all
Old 08-20-2014, 09:05 AM
D16y7 removed
D16y7 installed with 98k
Complete tune up
Kept the rest of the original things in
1999 Honda civic dx
Automatic
Old 08-20-2014, 09:37 AM
slogfilet's Avatar
Disengage the emergency brake. Free performance upgrade!
Old 08-20-2014, 10:45 AM
Outrun's Avatar
Get a timing light.
Old 08-20-2014, 11:14 AM
Outrun's Avatar
Old 08-20-2014, 04:18 PM
My car idles fine though. And it turns on right after the engine turns over twice just like every other civic out there. Should I still try this?
Old 08-20-2014, 04:36 PM
Outrun's Avatar
My car had the same symptoms as yours a few years ago. The timing was off and it was fine after I adjusted it.
Oday0111
08-25-2017 06:10 AM
vxnine
15
02-11-2005 05:40 PM
jiggagnome
Honda S2000
01-05-2005 12:58 PM
d0nkeyxPunch
06-17-2002 07:33 AM
Quick Reply: Slow acceleration off first gear
