96 Civic/b18b1 swap - Code 63 Won't Go Away
Car: 1996 Civic Hatchback CX w/ b18b1 swap
My exhaust setup is stock b18b1 header, Civic EX OBD2 cat, EX Midpipe, Stock Muffler
When I swapped in the car, I extended the O2 sensor wires myself (dumb idea, I know). After realizing it was a bad idea, I bought the harness's because I was throwing CEL's for both O2's.
After I installed both O2 extension harness's (shoutout HondaPartsHero), my primary O2 CEL went away, but my secondary O2 was still throwing Code 63.
I replaced the secondary O2 sensor, because I wasn't sure if it was faulty or not. After replacing the secondary O2 sensor, my CEL has returned. Not sure what to do now, someone was telling me it could be my cat because it's from a civic not integra.
Any Input is Appreciated, Thanks!
Re: Code 63 Won't Go Away
You will need to buy a DVOM, learn how to use it and search for the ecu pinouts for the secondary o2 sensor. Perform a voltage drop test and a continuity test from the ecu to the sensor.
Report back
Report back
Edit: just saw the diagnosis tree posted above me, it wasn't coming up on my phone.
Thank you, HondaPartsHero, I will need to stop by HB and pick up a multimeter.
Question: Does my Civic EX Cat have anything to do with this CEL? It's an Integra engine with an EX Cat, if I put in an integra cat would that do anything?
Thanks.
Thanks.
The tests will tell you if the wiring is good. I dont have the Honda diagnosis tree chart in front of me, but if you find it, I'm sure it will tell you what resistance values the oxygen sensor should have. That will tell you if the sensor is compatible with your ecu requirements.
Anyways, if your converter is of good quality and in good health, it should be able to handle the task. If it was already weak or deteriorating, then it could cause issues. But usually what happens to a converter is the "honeycomb" material nurns/melts into a solid state and blocks your exhaust flow, creating a 'bogging' feeling when trying to accelerate.
Not unless your converter is damaged or ruined. A converter takes any unburn fuel molecules(easiest explanation) and reburns them or changes their form into a harmless form like nitrogen, Carbon Dioxide or water vapor. Again this is the 1st grade class version...
Alright here are the results so far,
Resistance between male terminals 3/4 - 13.1 Ohms (OK)
Continuity between male terminals 3/4 individually - Both No Continuity (OK)
This is where i started to get confused,
Voltage Between Female Terminals 3/4 - the voltage was jumping all over the place, it never was set at one number; does this mean I am getting voltage or not?
Re: 96 Civic/b18b1 swap - Code 63 Won't Go Away
Alright I'll drop by there and report back ASAP.
Going to try to BAR my car tomorrow since I already booked the appt. 2 weeks in advance. Let's hope i can get this figured out.
My terminal 1 is red/yellow and terminal 2 is red/white, not sure if that matters, but i did the short check on the red/white wire.
Voltage .3 or Below W/ Engine at 3k RPMS - Yes
Voltage .3 or Below W/ Engine at Idle - Yes
Disconnect Connector D at ECU, Continuity Check Terminal 1 W/ Body Ground - YES
I assumed grounding the multimeter to the negative terminal of the battery would suffice. So this means I have a short in that wire? How can i fix that?
Thanks for the help thus far.
Terminal 1 is the Wht/Red wire. You are misinterpreting the connector diagram. Terminal 2 is a Red/Yel wire. Terminal 3 is a Blk/Yel wire. Terminal 4 is a Blk/Whtwire.
And you are not doing a short test, which measures Ohms or continuity not voltage.
Im using the wiring harness from my stock d16y7 obd2a.
I thought I was supposed to be doing a short test, or are you saying that I'm doing it incorrectly? I'm a tad confused.
