HELP HELP HELP!!!! B16a swap into 1.4 ej9 no vtec, iat and map sensor
#26
Re: HELP HELP HELP!!!! B16a swap into 1.4 ej9 no vtec, iat and map sensor
i already tried that mate i read something about that too i swapped them over reset my ecu and let the car idle for around 6 minutes it was idling really really rough then it died and it wouldnt start back up at all so swapped the plugs around again and it fired back up as it was before :/
#27
#28
The plug that goes into that one was the plugs I swapped over with the ait plug to try and like I said it idled badly for around 6 minutes then died and failed to start untill I swapped them back over and I reset the ecu after swapping the first time :/
#32
I will check and take pictures tomorrow guys thanks but yeah same codes came back 3,10,20 :/
#33
#35
I'm guessing that's where my map sensor shoud be as there is no map sensor to be doing at all anywhere and the plug is identical to the one that is supposed to be attached to a map sensor
#36
Update:
I received a map sensor and hooked it up and code 3 is gone but now have an idle problem....
On start up it goes straight to 2,500 then slowly drops to 1,800 and stays there still have a code for iat and eld.... Also one if the vacuum lines on the charcole canister doesn't go anywhere there's one going from the canister to manifold but there isn't anywhere from the other hose to go....
egfong
05-31-2008 12:45 PM
Metal_SOL
07-20-2002 04:08 AM
