Adding 12 volt Outlets
I usually add a separate fuse block inside the car so I can install additional 12v outlets and accessories. Is there an easy way to get a wire from the battery through the firewall in a 2015 Fit?
Re: Adding 12 volt Outlets
Look to where the A/C hose go into the cabin. Tape the wire you want to use to a straightened coat hanger. Carefully push the hanger along the hose into the cabin go inside or have someone inside pull the hanger until the wire is inside.
Got it!
http://www.amazon.com/s/ref=nb_sb_no...lue%20switches
