The rebirth of 1994 DelSol
Old 08-04-2014, 06:57 AM
CESAJANS's Avatar
Default The rebirth of 1994 DelSol
Friends Greetings to everyone...
It took me four years to realize this project.
I wanna do to create a powerful and reliable, compact super car :D
I wanted to update the complete brake system, interior comfort,
I wanted a vehicle that is safe and very best stable control.
I wanted a car accelerating very quickly, balanced, and can be stopped very quickly..
Yes I know I want much more than the DelSol's capabilities :D
Lets start the project..
My plan:
1- external appearance paintwork changing the colour, new custom style front and rear bumper, front and rear lighting, rims and wheels, etc..
2- Custom interior design.. Alcantre, carbon fiber and some glow paint work at some trims.
3- Breake system update, all driveline uptate..
4 - All motor for B16a2, all interior parts update to forged parts, electronic parts uptade, ecu ems, electronic Ignition system uptade, etc.
My Goal: +250whp! 11.2cr , STANDART STROKE @ 8250rpm. with 0.9bar JRSC
Old 08-04-2014, 07:07 AM
JDM_SOHC's Avatar
Default Re: The rebirth of 1994 DelSol
13psi on a stock b16, with an 11.5cr..?
Old 08-04-2014, 07:49 AM
CESAJANS's Avatar
No way I think u didnt read carefully..
"4 - All motor for B16a2, all interior parts update to forged parts, electronic parts uptade, ecu ems, electronic Ignition system uptade, etc.
My Goal: +250whp! 11.2cr , STANDART STROKE @ 8250rpm. with 0.9bar JRSC"
Old 08-04-2014, 08:10 AM
I never narc'd on nobody!
NotARaCist's Avatar
What you're saying is contradicting itself. If you're using a JRSC, you aren't all-motor anymore. 1 BAR = 14.5 PSI, so .9 BAR = 13 PSI.
Old 08-04-2014, 08:50 AM
JDM_SOHC's Avatar
At least I'm not alone on this one lol..
Old 08-04-2014, 12:22 PM
andoxviii's Avatar
His English obviously isn't perfect...I don't think he means "all-motor" the same way that we are thinking.
He is building a B16 at stock bore and stroke with forged internals and boosting to 0.9 bar on a JRSC.
OP: Out of curiousity, which country are in you?
Old 08-05-2014, 09:15 AM
CESAJANS's Avatar
Ohh thank you
Yes that what i I said exactly this :D
I am building b16 at stock bore & stroke but all parts with forged internals.
And i will use b20 big Crank pulley +3.8" blower pulley for around 1 bar boost gain.
Iam from Türkiye...
Old 08-05-2014, 09:23 AM
CESAJANS's Avatar
iam starting my project with engine removed.
Old 08-05-2014, 09:30 AM
CESAJANS's Avatar
This is my some parts list for my DelSol..
Motor :
- ACL Race Rod Bearings STD
- ACL Thrust Washer
- ACL Main Bearings
- AEM Adjustable Fuel Pressure Regulator
- AEM Coil-On-Plug (COP) Conversion Kit B-Series
- AEM Cold Air Intake System Honda Civic 92-93
- AEM 340LPHfuel pump
- AEM V2 Water/Methanol Kit
- AEM EMS Series 2
- ARP Pressure plate bolt kit
- ARP Flywheel bolt kit
- ARP Crank Bolt
- ARP Main Stud Kit
- ARP 208-4601 Head Stud Kit Honda Civic B16A
- Blox Racing BXFL-00300 Manifold Stud Kit
- Blox 8-piece Exhaust Manifold Stud Kit
- Blox billet aliminyum cam seal
- Brian Crower H Beam Rods
- Cometic Head Gasket B-Series B18C1/5, B16A DOHC 81.5mm Bore 0,30"
- Competition Clutch 93-96 Del Sol VTEC B16A CC Ultra Lightweight Flywheel
- Competition Clutch B16A B16A2 B20 Stage 4 Ceramic coated 6 Pad
- CP Forged Pistons B16A LSVTEC B18A/B16a 81.5mm 9.8:1 - 11.0:1
- Eagle 3.031 Forged Crank STD Stroke Honda Civic B16A1 B16A2
- ITR Yamada water and oil pump
- Ichiba motor mounts
- Golden Eagle Block Guard
- Golden eagle magnetic oil drain
- Golden eagle billet aliminyum Crank Gridle
- Heavyset RED Hose kit for B16 Honda
- Jackson Racing B16 SC
- MFactory Helical LSD Civic CRX B16A Integra LS B18A/B 4,40
- Motec 3.5 bar map sensor
- Mugen carbon külbürtör buji kapağı
- Mitsimotho 10" Slim race electric fan
- Mitsimotho racing thermostad
- Mishimoto Heat Wrap Roll with Stainless Steel
- NRG torque damper
- RC FUEL INJECTORS 440cc
- Skunk2 Tuner Cams Stage 1 Civic Si B16A Integra GSR
- Skunk2 Black Series Cam Gears set B16
- Skunk2 Alpha Series Valve Springs and Ti Retainers B-Series
- Skunk2 68mm Pro series Billet Throttle Body B16 B18
- Skunk2 B16A / B18C B18C5 Type-R Intake Manifold Thermal Gasket
- Skunk2 Alpha Series Valve Set Acura Honda B-Series VTEC
- SKUNK2 ALPHA SERIES RACE HEADER 94-97 HONDA DEL SOL 2,5"
- SKUNK2 ALPHA SERIES ALIMINIUM RACE RADIATOR 94-97 HONDA DEL SOL
- SKUNK2 BLACK ANODIZED FENDER WASHER KIT LARGE
- Synchrotech 1st to 5th Carbon Synchro Set
- TEGIWA EXHAUST MANIFOLD GASKET B16A
- WMS ENGINE RED DRESSUP KIT
- Varex 76
And some parts photos..
Old 08-05-2014, 09:46 AM
I like the tuna here
DumpdEJ6's Avatar
I read the parts list and I was like "Yep, here we go again...another broke dude with big dreams...never happen."
Scrolled down and was like "O-K...never mind!"
OP, looking forward to seeing how it turns out. Correct me if I'm wrong though, guys, but don't you want lower compression for forced induction? I know you CAN do it with high compression, but your tune has to be spot on and it's still likely to be less reliable?
Old 08-05-2014, 09:53 AM
Fnix's Avatar
Always motivating to see people from countries without a big honda scene going all out. I bet the parts are 3 times as much in Turkey.
Old 08-05-2014, 10:00 AM
CESAJANS's Avatar
i bought all parts from ebay, i only paid mucher shipping price than you, thats it!
Ryd2TheMax, why did u say like that? impossible with 11.1 cr with 0.9 -1 bar boost??
Old 08-05-2014, 10:08 AM
CESAJANS's Avatar
Whatever, some theother parts list ...
- K-Tuned Pro Series Traction Bar 92-00 Civic 94-01 Integra
- WILWOOD F&R DISC BRAKE KIT, 12.2" HONDA DEL SOL W/ABS,RED CALIPERS
,DRILL​ED ROTOR
- Skunk2 HARD Anodized Rear Lower Control Arms
- Skunk2 Pro Series Rear Camber Kit EF EG EK
- Skunk2 Pro Series Plus Adjustable Front Camber Kit EG
- Skunk2 Pro-C 12 Ways Adjustable Coilovers 92-95 Civic EG
- VMS RACING T-6061 ALUMINUM ANODIZED STAINLESS STEEL-ZINC-PLATED REAR SUBFRAME KIT
- INNOVATE 3796 DB DIGITAL AIR FUEL RATIO GAUGE WITH LC-1
- INNOVATE 3844 MTX-L DIGITAL WIDEBAND AIR FUEL GAUGE KIT
- INNOVATE Motorsports MTX-D Vacuum / Boost & Shift Light 3851
- AEM AEM Water/Methanol FAILSAFE Device - 4mm Metric 30-3020M
- AEM (30-3300) V2 1-Gallon Water/Methanol Injection Kit with Internal MAP Sensor
- Honda Civic Del Sol CR-V Acura Integra Mud Flap Clip
- Honda Civic Del Sol CR-V Acura Integra Hood Seal
- Honda Civic EG EK EX EF SI Del Sol Accord Odyssey Fender
- Honda Civic Del Sol CR-V Acura Integra Wheel Arch Fastene
- Honda Civic SI EG EK EX EF Del Sol Accord Odyssey boot
- Civic Del Sol CRX Aluminum E-Brake EBrake Handle RED
- HONDA CIVIC DEL SOL CRX GENUINE LEATHER SHIFT BOOT
- H4 BI-XENON HIGH-LOW HID CONVERSION KIT CANBUS BALLAST 55W
Old 08-05-2014, 05:59 PM
94 accord typeR's Avatar
well u got the parts, now u have to put it all together! LOL j/k
but seriously u are going to make a lot of people jealous just be prepared for that.
Old 08-06-2014, 12:20 AM
CESAJANS's Avatar
This is my old interior view..
I started my project with my interior, trims, seats, flooring, dashboard etc..
Old seats foam rubber looking before fixing :D
Black real leather & orginal Lamborgini alcantara and sports stitches with some handmade working :icon_tup:
I made a 3 slot indication pot for my dash board.. u ll see on next photos.
I took all of the dash board parts, for alcantra coating and for plastic parts painting...
Doors,
Consoles,
B]I am working on radio console for double din system and more area[/B]
I need more space on this console for future plan :D
It need some modification on metal frame, cutting some area on it,
U ll see different on this photo, before and after..
to be continued......[/QUOTE]
Old 08-06-2014, 01:21 AM
shotoutacc0rd's Avatar
Did you buy a security system!?! GPS tracking bro GPS tracking hidden under the dash.
Old 08-06-2014, 01:43 AM
CESAJANS's Avatar
No!! I did not think about this, but iam thinking to buy it now
Old 08-06-2014, 04:12 AM
andoxviii's Avatar
Wow. As a Del Sol driver, I would be stupid not to follow this.
Subscribed.
Old 08-06-2014, 09:22 AM
Subscribed.
OP got some "Mad Skillz"
Old 08-06-2014, 09:49 AM
andoxviii's Avatar
^^ Not sure what you mean by that, but Del Sols aren't common. And it's cool to see someone do tasteful, custom work like that to one. Hence my interest.
A buddy of mine sells Mini's. And they have a "Rolls Royce" edition that has everything inside wrapped in leather with stitching similar to this. And lambskin mats. Pretty nice looking stuff. I know he would be interested to see someone wrapping the interior of a Del Sol because he likes them a lot.
Old 08-06-2014, 09:50 AM
Oh look, I can change this
deschlong's Avatar
Velvety goodness.
Will your floor mats be .... Turkish carpet? I would love it if this was true!
Old 08-06-2014, 10:27 AM
JDM_SOHC's Avatar
lmao so did i..!!
Old 08-06-2014, 11:14 AM
CESAJANS's Avatar
Next, raido console....
iam shure photos would tell u whats going on
Old 08-07-2014, 07:32 AM
civicophy's Avatar
SUBSCRIBED! That thing is going to be so sexy. You got mad skills.
Nice picture taking too, its making it really fun to follow along
Old 08-07-2014, 01:54 PM
quik sol's Avatar
I'm in love with this project....awesome work
Quick Reply: The rebirth of 1994 DelSol
