August FS thread
#26
Re: August FS thread
-For Sale
BBK B18c GSR Intake Manifold with 75mm Throttle body $300 Shipped or only Manifold $225 Paypal Ready email. or text Jdelcorte@gmail.com or 203-589-7790
B Series T3 Spa top mount manifold, with 38mm waste gate flange, $175 Shipped! Can keep Ac, and power steering Email me for questions and pictures @ Jdelcorte@gmail.com PAYPAL READY<
#27
-Injector Dynamics 2200cc injector for B/H/F/D Bought these from xenocron a few months back. These were installed, ran at idle with pump gas, and removed not long after(basically brand new) Include's everthing you see in the picture plus and extra set of o-rings. $850 shipped!
#28
-Rywire OBD1 MIL-Spec B & D series harness. Include's 92-95 civic cabin harness, and is setup for OBD1 alt. and dizzy plugs. The injectors plugs have been cut off, but you can easily solder in your own injector plugs. The IAT sensor plug wiring was extended to reach the iat sensor placed in the charge pipe. $475 shipped!
#29
last I have a edelbrock intake manifold 4765 for a b16 or type r has two dyno sessions on it and was painted with bed liner paint has some scrathes to the paint it comes withgolden eagle primary and secondary fuel rail to run 8 injectors it comes with fittings and fuel line from one rail to the other no sensors no injectors 400 shipped
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#30
Aem in tank 320 80.00 shipped. No pics pump is still in the car. This was used in a drag car so only has less that 2 hours operating time. Mods I am not taking the pump out to take pics.
#32
Up for sale are a set of almost new kelford stage 2 camshafts for kseries motors, these cams are almost new with only a couple hours( if that) run time. Any questions or concerns cwatson876@gmail.com or pm me on here thanks!
http://www.camshaftshop.com/products...70#recommended
Asking $550 shipped plus Paypal.
#33
hi I have two sets of 2150cc injectors one set has two dyno sessions on them and the other has 4 dyno sessions through them both work great 1 injector has a loose oring that could be change or not its still fine both used with e85 if u are gonna let them sit for a while you will have to clean and lube them up price is 625 each set shipped
top set
[IMG][/IMG]
bottem set
[IMG][/IMG]
top set
[IMG][/IMG]
bottem set
[IMG][/IMG]
#34
*Brand new* Precision ball bearing 6262 $1400 shipped FIRM! Including vband clamp and flange for free. Was $80 alone. Turbo was only mocked up. Never used.
Brand new tial 44mm wastegate $340 shipped
virgin p28 ecu $100 shipped
obd2a<obd1 harness $40 shipped
#36
B16 Head with out cams $600
Supertech springs and retainers
ferrea valves
SK2 pro 3s SOLD!!
SK2 adjustable cam gears SOLD!!
B16 Trans PENDING!!
MFactory 307 First gear
4.7 Final drive
Quaife LSD
cut syncros
Comp Super single clutch and fly wheel SOLD!!!
PLM V2 Header SOLD!!
Golden Eagle fuel rail $80
Victor X Manifold $275
SK2 Throttle body SOLD!!
Precision 1000 injectors cleaned by SouthBay $250
Aem FPR SOLD!!
Catch can with lines SOLD!!
#38
T1 M&W Pro 14 kit with CBR coils and billet spark plug cover. Has some dyno time and 4 passes on it. $760 shipped including paypal. Text 7578182917 for quickest response.
MoTeC M800 untermed wiring harness. 650 shipped and paypal.
MoTeC Ignition Expander. Brand new!$350 shipped and paypal.
[IMG]http://i1132.photobucket.com/albums/m567/boostedekhatch/F044E2FE-6C00-4970-8BC2-
51A98A2C06FA.jpg[/IMG]
#40
Bnib fuel injector development 2000cc injectors. My setup has changed and these are more then I would need going back to 1000cc
$600
Pm or text 9oh2 3oh4 24five8
The flow chart was a picture email to me from fid cause it was misplaced and wasn't shipped with the injectors
$600
#41
Holset HX40 T3 with BEP .70AR V-band Exhaust housing (Excellent condition no smoke/shaft play) $500 OBO
Tial 44mm vband wastegate - Silver w/ 7 PSI spring $200 OBO
Synapse synchronic BOV $130 OBO
#43
Bvtec valve cover. New gasket and tube seals. Shaved and painted wrinkle blsck. New- 16 bungs with black caps
$100
Fragola -16an hose end x3 (new)
Black anodized, 90degree
$30 each
Fragola -16an hose end (new)
Black, straight
$20 each
Earl's anotuff black hose ends (new) x2
-12AN, straight
$10 each
4" mandrel bends (new)
Mild steel
2- 45degree- $15each
2- 90degree-$20 each
Autometer water temp gauge, used
smaller version.
$10
Golden eagle mfg intake gakset. Used
For b16/itr
$10
Mr. Hero propane heater. Bought in 2012, only used a handful of times.
$130
$100
$30 each
Black, straight
$20 each
-12AN, straight
$10 each
Mild steel
smaller version.
$10
For b16/itr
$10
$130
#44
Selling some stuff - went with a K24 instead
All items only have idle time (all pics at bottom)
Please add 3% or gift when paypaling - free shipping to lower 50
Home ported GSR head
Supertech black nitride flat faced valves
KMS springs
KMS titanium retainers
extended exhaust manifold studs
comes with cam seal
(NO VTEC SOLENOID)
$700 shipped
Bseries BWR gold camgears
$130 shipped
Black Golden Eagle fuel rail
(comes with the stock plug/fuel fitting, does not come with purple fittings)
$100 shipped
ATI superdamper for Bseries
$300 shipped
Stock ported B16 throttle body with FITV blockoff and thermal gasket
(comes with tps and stock map)
$80 shipped
Bseries Accel wires
$35 shipped
B16 used ARP headstuds
(torqued 3x)
$50 shipped
Edelbrock victorX GSR manifold
(comes with all fittings and thermal gasket)
$250 shipped
Blox stage 2 cams
(mint condition)
$350 shipped
Please PM if interested! thanks!
KMS springs
comes with cam seal
(NO VTEC SOLENOID)
$700 shipped
$130 shipped
$100 shipped
$300 shipped
$80 shipped
Bseries Accel wires
$35 shipped
(torqued 3x)
$50 shipped
$250 shipped
Blox stage 2 cams
(mint condition)
$350 shipped
#45
F/S: 15x8 and 15x4 CCW LM20 street/drag pack. Centers are done in a shot peened/textured bright clear anodize with polished lip and inner barrels. Wheels and tires are basically new (maybe 50 street miles) 235/60-15 M&H street & strip up front, 24x3.6-15 M&H skinny's out back. Wheels will include center caps, and lug nuts. Clears up to GSR brakes
$2300 plus shipping with tires. $1750 plus shipping without.
Prices do not include shipping/paypal fees (unless otherwise noted)
MoTeC M4 box
M&W Pro14
Motec ignition expander
T1 cam trigger (Including one Golden Eagle cam gear with magnets)
CBR coils
Motec engine harness
$2750 (NOT SPLITTING UP)
AN fuel line, for use in stock location (EG/DC/del Sol)
-Includes new fuel filter, all you need is fitting to connect to fuel rail (may have it, if you let me know which size you need)
$75 plus shipping
Block plug, and (1) block port to -10an fitting for B series
-Brand new
$20 for block plug, $25 for for fitting. $40 for both
MSD cap for external coil for GSR
$40
Skunk2 ProSeries 70mm Throttle body for B/D/H
-brand new, only mocked up
$200 plus shipping
Recaro double lock slider
-Brand new
[b]$75 plus shipping[/b
BENEN 1st gen lower tie bar for eg/dc in black
-Great shape
$100 plus shipping
Custom dual back door intercooler.
-Good useable shape overall, has a few dings, but shouldn’t affect the flow
$250 plus shipping
MoTeC M4 box
M&W Pro14
CBR coils
$75 plus shipping
-Brand new
$40
$200 plus shipping
-Brand new
-Great shape
$100 plus shipping
$250 plus shipping
#46
For Sale excessive 58mm h series intake manifold with 58mm velocity stacks Omni 68mm throttle body adapter plate for throttle body golden eagle fuel rail throttle cable bracket bottom is tapped for direct port nitrous. ASKING $650 OBO.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#47
K-SWAP PARTS FOR SALE. if interested message me or Text me 404-558-6234
Located in Atlanta GA
- All items are in perfect working conditions -
PayPal Transactions ONLY!
RC 750cc Kseries Injectors $250 SHIPPED! and PAYPALED
Kswap Fuel Setup COMPLETE - $230 FIRM SHIPPED and PAYPALED!
TypeS Box/cables - $200 SHIPPED AND PAYPALED!
Exedy Clutch/Comp Ultra Lightweight flywheel - $500 FIRM for both SHIPPED!
Less than 50Miles
Drag Cartel 4 cams. $860 SHIPPED and PAYPALED! complete with gear and actuator. Cams have less than 50miles on them
BRAND NEW Synchro Hylical cut 1-2 gear set. Extended 1st gear. Perfect for ALL MOTOR SETUP. Rated to 700HP. $500 FIRM Shipped and PayPaled.
Purchased from MARTY: Werksjdm
Less than 50Miles
#49
ALL PARTS ARE BRAND NEW!!! Buyer pays for Paypal fees unless pick up.
Borg WarnerS400SX FMW Turbo (Billet wheel 67mm) 1.25 a/r housing w/ vanjen clamp, 4" up pipe $1300 + shipping
Blueridge motorsports T4 twin scroll top mount dual 44mm gate flanges $650 + shipping
2 TiAL MVR 44mm Waste gates & dump tubes (black) $300 ea. + shipping
Custom dual back door intercooler made by HUBCITY PERFORMANCE (Garrett 925hp rated core) with
3" piping, Tial 50mm BOV, with 3 vanjen quick release clamps
gsr victor x manifold w/ 75mm mustang throttle body w/ hondata thermal gasket $1100 + shipping
Engine: block $3200 plus shipping
Built and assembled by Jeff Evans @ Evans Tuning. I believe he used Inline Pro for the head work.
B18c1 block w/ AEBS Sleeves, oringed
gsr crank, polished and balanced.
cp 81mm 11:1 pistons w/ upgraded wrist pin, manley turbo tuff rods
Acl race bearings, GE oil squitter plugs , ATI balancer.
head $1600 w/cams + plus shipping
b18c1 head, 5 angle performance valve job
Skunk2 pro series dual valve springs, skunk2 pro series titanium retainers
Skunk2 pro series stock size dished valves, ungraded bee hive LMA's
and rocker pads modded for spring clearance
b18c1 Skunk2 pro1 cams $560 shipped
Transmission: $1250 + shipping
b18c1 hydro, mfactory LSD, mfactory longer 1st gear, 5th gear delete cuff
b18c1 comp clutch twin disc and flywheel 0miles $950.00 +shipping
b18c1 Ferrea comp+ intake valves $230 shipped
b18c1 Ferrea Comp+ exhaust valces $230 shipped
b18c1 ferrea dual valve springs (turbo 95lbs) $400 shipped
b18c1 ferrea titanium retainers $200 shipped
b18c1 ferrea valve seat locators $100 shipped
bseries ferrea valve guides intake and exhaust $100.00 shipped
supertech valve seals $25.00 shipped
Mishimoto triple core radiator with fan and shroud w/-16an water outlets $500 + shipping
