View Poll Results: How do you tighten tappet locknuts & valve cover acorn nuts?
Voters: 8. You may not vote on this poll
Valve Adjustment Questions
Hey guys. Wondering about 2 things.
1.) How many of you guys use a torque wrench to torque the locknuts to spec... and the valve cover acorn nuts, and how many just do it by feel?
2.) In several write ups, as well as a youtube video all for this same procedure, the valve clearance is being measured by sliding the feeler under the tappet screw. I have a copy of the Honda service manual, not a Helms or other 3rd party service manual, but the ones that Honda technicians use. In that manual, they show the clearance being measured in between the cam lobe and rocker arm. Does anyone else do it this way?
moderator emeritus
Re: Valve Adjustment Questions
the ONLY way to measure the clearance is between the cam lobe and the rocker pad. no other way will give you a reading on the clearance, you have misunderstood.
I was just saying that in several write-up's I've seen on various websites/forums, and a YouTube video, the people were using their feeler gauge under the tappet screw, NOT in between the cam lobe and rocker pad. That struck me as odd, considering that in the Honda service manual for 5th gen preludes, it clearly depicts it being done in between the cam lobe and rocker pad.
I think whoever is measuring under the screw might have a screw loose haha.
AS for the torques, I am with Blake, and have developed a good hand for those guys, but would recommend a torque wrench if not sure. Especially the acorn nuts, they strip out so easily if over-torqued.
If you want piece of mind use the correct torque, I know in the manual it says tighten with a wrench while holding the adjustment screw in place, but I've never had a problem with the adjustment screw over-tightening when torquing the locknut, of course always double check.
I think the videos you have been watching where the feeler gauge is used directly under the adjustment screw may be of an OHV engine
hint: the manual will say something like 0.003-0.004... it means you want the 0.003 to fit but not the 0.004 feeler gauge to fit or else you'll still be 0.004-0.005
hint 2: it's easier to insert the feeler gauge from the opposite end of the cam nose (the manual shows a feeler gauge being inserted on the nose side)
hint 3: removing the spark plugs makes it a lot easier to crank the engine since it doesn't need to compress, DO NOT rotate the engine clockwise at all, crank counter-clockwise only
Why is this even a question. If you have to ask these kinds of questions, you clearly cannot work on cars very well. Use a torque wrench and save your ***.
Blindeye_03
11
03-10-2010 03:29 AM
