Outer tierod "balljoint" kept spinning...why.
Old 07-31-2014, 05:49 PM
B_Swapped93's Avatar
Default Outer tierod "balljoint" kept spinning...why.
Was helping my friend with his teg we took the knuckles off to do the BJ/wheel bearings. Point is when we went to put the nut back on the threaded part kept turning nothing was stripped or bent, this happened to me a few times when I owned a civic/integra. just wondering why it happens doesn't just happen with the tierods I've had the lower and upper BJ's do it too.
Old 07-31-2014, 06:04 PM
95accordCE6's Avatar
Default Re: Outer tierod "balljoint" kept spinning...why.
Just get worn after a bit. I mean it's a ball and socket hence "balljoint" use a pry bar to add tension so the ball won't spin as easily and if using an impact bump it repeatedly rather than constantly spinning, makes life a lot easier
Old 07-31-2014, 08:07 PM
B serious's Avatar
The threads stretch or there may be a burr or some rust on there.
Grab the non threaded part with vice grips. Don't tear the boot. Impact a good condition nut (with the right threads, obvi) up and down a bunch of times to "recut" the threads.
Now put it back in the spindle and the nut will go on smooth.
KraKimus
07-18-2009 12:32 PM
CARMA_626
02-22-2009 06:48 AM
bow tie
02-07-2008 08:26 AM
f@sth@tch89
03-01-2004 06:04 AM
sivik2nr
10-01-2002 07:27 PM
Quick Reply: Outer tierod "balljoint" kept spinning...why.
