shell rear wheel stuck
I bought a DA integra shell a couple of years ago and now its time to get it running. I went to push it out and the car won't move at all. It's been in the garage for 3 years and when I first brought it home the wheels moved perfectly fine. Can you guys help?
Re: shell rear wheel stuck
Sure can. Just give me a dozen hours to drive out there.
The first thing I will do is to determine which rear wheel is stuck, and then use a big screwdriver to pry the brake pads loose so the car will move.
Do you still need me to drive out there? I haven't been to Beer Zoo in ages, so maybe it's time for another visit (yes, I know it's actually in Swatara, but that's close enough).
The Credible Hulk
If you stored it with the ebrake on the shoes froze to the drums. Jack it up, take the wheel off and whack the **** out of the drum with a hammer. Should do the trick.
If it doesn't you need to use a flathead to manually back the shoes off from the drum a bit, then whack the **** out of it again..
Civic44
05-16-2002 09:04 PM
