P0141 Code help 1996 civic hatch
Old 07-30-2014, 01:52 PM
adzenry25's Avatar
Default P0141 Code help 1996 civic hatch
hey guys today i change my catalytic converter on my 1996 civic hatch and when i was finish i got a p0141 code i tried to reset the code and it comes back on immediately. please help
Old 07-30-2014, 02:02 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: P0141 Code help 1996 civic hatch
Did you plug your secondary O2 sensor back in? Did you possibly damage the wires in the process?
Old 07-31-2014, 03:15 AM
adzenry25's Avatar
Yes i did plug it in and it was away from everything for it to be getting damage
Old 07-31-2014, 08:50 AM
OptimisticWay's Avatar
Was this code present before the catalytic converter installation?
Old 07-31-2014, 08:52 AM
Old 07-31-2014, 09:49 AM
StillBaggn's Avatar
When I got this P0141 code it ended up being the heater element inside the downstream sensor was going bad and was giving false readings. I replaced the downstream o2 sensor with a bosch OEM replacement, fixed the problem!, but now that I had a new/working downstream o2 sensor, it detected that my catalytic converter is bad with a PO420. :/ seems you can never win.
Old 07-31-2014, 03:34 PM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/honda-civic-mil-cel-both-dtc-41-dtc-65-codes-3101253/
Old 07-31-2014, 04:16 PM
Fish Twig
tony_2018's Avatar
If you didn't handle the sensor with care and accidently dropped in some way that damaged the sensor you're gonna have to replace it. Follow through procedure to check the sensor and if it still comes up as the sensor is bad than you'll have to replace it.
Old 08-01-2014, 08:19 AM
adzenry25's Avatar
no it wasnt
Old 08-01-2014, 08:47 AM
re_volution's Avatar
Are you able to check the real time readings of your O2 sensors?
I had the same problem and saw that my downstream O2 sensors readings were way off. Replaced the O2 sensor, reset the code, and all was good again!
Old 08-01-2014, 09:50 AM
The Grumpiest
grumblemarc's Avatar
I'm not following. YOu replaced the cat but you're saying that you think because the code that is being thrown, the cat is bad? You do know a ton of other things will cause bad O2 sensor readings?
Old 08-02-2014, 04:32 AM
adzenry25's Avatar
i am unable to check it out at the moment
importnoodles
03-29-2008 10:20 AM
b_serious
01-26-2006 05:22 AM
iLOVEmyEMone
12-29-2005 02:57 PM
s14hybrid
11-24-2004 05:16 AM
Quick Reply: P0141 Code help 1996 civic hatch
