1994 Honda Civic CX Hatch w/GSR Swap (Not Cranking)
Please chime in if you can help...this is my only car and daily driver.....
Was driving this morning and then parked car. Got out for a few minutes and tried to start it and it wouldn't start.
-I turned key and I only heard a "click" under the dash
-Car won't crank at all (doesn't even try to crank)
-Still appears to have charged battery as radio/lights work fine
Is this:
1. Bad starter
2. Bad Main Relay
3. What else would this be??
Thank you for any ideas or help - I need to fix this TONIGHT!
Is this:
1. Bad starter
2. Bad Main Relay
Re: 1994 Honda Civic CX Hatch w/GSR Swap (Not Cranking)
Does your fuel pump prime? And is the *click* from the engine bay or dash?
If so then tap your starter and see if it will try to crank the motor, when my GSR did this I replaced battery and starter (needed a battery anyway) hope this helps!
Hondacrf
06-16-2017 04:13 AM
solk1dd
07-23-2007 06:25 PM
AspectIndustries
08-22-2004 07:35 AM
