Passenger axle chirping noise
Old 07-20-2014, 09:24 AM
Inextricabledrvr's Avatar
Default Passenger axle chirping noise
This is on a 97 Prelude SH with 256k miles.
What I've replaced recently so, you guys have a heads up on what's been done to the car recently.
1) Replaced both inner and outer tie rods
2) Replaced front and rear sway bar brackets and end links.
3) Replaced passenger axle
4) Replaced new tires and rims
Everything was going great up until the last thing I replaced. The passenger axle. After install, I noticed a chirping noise from the front passenger front wheel. Any input on what it may be before I put the car back in the air. I'm thinking bearings, but there was no noise before axle install. I will double check all all the parts replaced to make sure everything is torqued down properly.
Old 07-20-2014, 01:14 PM
holmesnmanny's Avatar
Maybe lower control arm bushing is bad. There are two. You can try shooting them with some silicone spray and see if the noise changes.
Old 07-21-2014, 02:32 AM
Default Re: Passenger axle chirping noise
Actually, it's possible to have damaged the bearing when you inserted the axle or it's possible you either didn't torque it enough or you overtorqued the axle nut. If you removed the pads it possible to have the pad chirping now as well. Just throwing things out there.
Old 07-25-2014, 08:53 PM
I re-torqued everything to spec. The noise is still there. I will go ahead and replace the wheel bearing to try and eliminate that part.
I am thinking maybe the new axle I put in could be the issue. I will keep you posted. Thanks for the info by the way.
acmoc
11-28-2012 10:20 AM
IntegraFanatic
04-22-2004 07:32 PM
penney
04-16-2004 06:58 PM
Stellar1
25
03-11-2003 05:35 PM
Quick Reply: Passenger axle chirping noise
