1998 Accord F23 oil in intake
This is what my intake looks like. Also have oil coming into coolant, but not coolant into oil. No coolant sitting on the bottom of oil plan. Loosing oil (obviously). Any ideas? Porous engine block problem?
Re: 1998 Accord F23 oil in intake
jesus how many miles on the engine? It must be coming from the egr system. In my opinion if your engine is severely burning oil then the gases will contain alot of oil which is being recirculated through your intake via the ports for the egr system. The previously burned exhaust is recycled back into the intake (some of it) and im thinking it contains a high amount of oil. Or your PCV is allowing oil to go back into the intake manifold. Its a direct tube from the top of the valve cover to the intake
When I had a bad block due to PEB - i could feel a power drop when on the throttle if i took the car over 4500 rpm normaly if i drove grandma you couldnt tell.
The black carbon you see isnt that much to worry about unless its wet - and the PCV valve would be the only quick fix for that -
http://www.hondaautomotiveparts.com/...=BREATHER+TUBE
part#2 PCV they are normally like 5$ at autozone
