94 accord non v cruise control inoperative
I got a 94 honda accord f22 engine everything all stock. My cruise control doesn't work. When I press cruise control button on the dashboard the green light lights up, not cruise control lights up on instrument cluster, and when I try to set the speed nothin happens. I don't know where the cruise control fuse is, is it under the dash on driver side? If so which one is it? I don't have a fuse box cover to indicate which is the fuse. What steps do I need to do to diagnose this problem?
Re: 94 accord non v cruise control inoperative
I suggest you download this, as it contains all the troubleshooting info...and everything else about the car: http://www.manualslib.com/manual/464...da-Accord.html
Check the fuse first, but yours is probably fine, since the same fuse covers the ECU.
I'll take a look at it.
Have not ever worked for me since I bought from previous owner. Which was about 3 years back but now that I have some tech experience I've been working on cars ever since I'd like to try and fix it and get it working.
test the brake light switch.....there are four pins, a set of two work the brake lights - the other set of two work the cruise.
Too tired to look up the pins/pic's but if the two for the crusie are not closed when the brake is not pressed then the cruise will not work but the brake lights will.
Next just for grins - try pressing the horn(s) as you set the cruise
My cruise control never worked. Not even the light on the dashboard. then I trouble shot EVERYTHING. Get a multimeter. Turned out to be the clutch and brake switch weren't set properly. Since your light comes on I would suggest
1. Checking the cruise cable it mounted correctly.
2. Check for vacuum at the actuator.
Does anyone have a direct page to go to diagnose my cruise control not working because that link is the whole manual and it's taking long to find because I'm using internet though my phone, I got no computer to use at the moment
Have you tested the brake light switch?
Do the horns work? If so, what happens is you honk the horn as you try to set the cruise?
Is this an auto or manual trans.
All of the testing and steps is in the service manual.
tedscreamer
07-19-2011 12:47 PM
