Accord stops running
What's up guys. So I'm trying to fix this 94 accord lx none vtec
I tryed to pull code and the cel stays on no flash what's that about any news is good news even if it don't fix the problem it one more thing that I don't have to worry about anymore
Re: Accord stops running
Randomly dies and the cel light stays on even after I reset it so I was told to jump the ecu while
The car was runnin I did so and still the cel stays on then I was told it might be a bad ecu idk.
If the engine light stays on after jumpering the service cconnector that means there is no code.
If it doesnt immediately start back up you need to check for spark and fuel to help narrow it down.
It's a new day. I spent some money on this car and found over all I'm not getting all the power I need to the conector at the fuel Main relay box the ground wire going to the conector is good. the wire that is always hot that go's to the conector is good. But the wire that gives power when I turn the key on is not getting power is there someone that knows how the harness gets it power and where so I can trace it down? I realy need some help with this car I keep herring all the same stuff but everything I'm told is not the problem it's stuff like
Check the ground
Check the main relay
Check the icm
Check the spark
Check the coil
Check the dizzy
Check the iac valve
Check the purge control valve
Check the fuel pump
Check the line from the fuel pump power to the conector
So all that checks out need to know what to do next
Check the ground
Check the icm
Check the spark
Check the coil
Check the dizzy
Check the iac valve
Check the fuel pump
Guess what big ups and much thanks to JJ out of tucson for fixing the problem Bad ECU
I didn't see it coming and real big
Thanks to Jehovah my lord for
Sending me to JJ . So ya ecu he said I fried it some how putting woofers in the car and not being careful on what i touch with wires will do that sometimes.
