Cam Question
Old 07-11-2014, 07:01 PM
187Chor's Avatar
Default Cam Question
I just aquired an 02 type S it came with a cold air intake and im putting headers and a cat back exhaust as soon as it arrives in the mail. After that I would like to put in better cams that will work with my bolt ons as well as ecu tuning that i will do at the same time. Can anyone recommend a cam or "stage" of cam i should be looking for. Id like to be able to make a little bit more power higher in the power band hoping this can increase my top speed if even by only a few km. I also need it to be streetable for daily driving I dont want idle problems.
Thanks for the help
Old 07-14-2014, 06:43 AM
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: Cam Question
My recommendation is kelford Cams stage 1 or even go for stage 2 but make sure you do a valve train upgrade. I'd also do bigger fuel injectors too.
Or maybe if you want something cheaper do like a factory 06-08 K24A2 cam setup. Also valvetrain upgrade
Old 07-14-2014, 01:57 PM
187Chor's Avatar
Ok thanks
but what size injectors should i get? What is the factory size?
vtecmasta85
29
09-16-2013 02:16 PM
wantboost
11-11-2005 10:10 PM
polishprinze
01-31-2005 02:51 PM
IntegraGSR321
09-17-2004 08:10 PM
RACING INTEGRATION
03-19-2003 04:40 AM
Quick Reply: Cam Question
